Jr r921 rx
My Feedback: (12)
IN
Jr r921 rx
I have 3 JR R921 receivers. The slots in the plastic case for aligning the connnectors for the battery, servos, telemetry, etc seem to be slightly under size making it extremely difficult to plug anything into the RX. I am using JR and Spektrum equipment so don't know why they are so tight. Not having the problem with the Spektrum AR7000 Rx. Has anyone else experienced this problem?
My Feedback: (17)
Do your R921's have red cases or black? My two with red cases are really difficult to get servos plugged into. I just received a R921 today that is black and is much easier to get plugs into, just like my AR7610. You can buy new black cases from Horizon. http://www.horizonhobby.com/webapp/w...pe=productgrid I probably should buy two new cases since one of them is cracked on the bottom from plugging in the battery and binding plug.
Chuck
Chuck
The case will snap apart but there is the danger of breaking one or more of the latching tabs. The problem may not be the receiver case slots are too small but the servo plugs are too large. The plugs do vary in size. The plugs JR uses on its servos should fit into the receiver with no problem. I have had other servos and devices using the universal style plugs that wouldn’t.
Allan
Allan
