receiver battery for smoke pump
NY,
Hi Danny
I use dual 2700 mah receiver batteries thru separate switches for redundancy. TME smoke is removable. When I fly with smoke, I would like to use power to receiver batter(ies) to run the TME smoke pump - saving weight and hassle of separate pump battery and charging circuit. This would put the smoke pump in parallel with the receiver buss. The pump runs thru a speed controlle. Is this ok, or would one expect electrical noise to feed back thru the receiver?
RJM
RJM
RE: receiver battery for smoke pump
Electrical noise will feedback to the receiver, but this will happen regardless of using the battery power from the receiver or not. The range will be reduced to a degree with a smoke system, if this becomes a problem or not depends on the set up of the model. Generally it will not, but it is possible. Personally I do not like the idea of running the smoke pump off of the receiver power, but I know that people have done it successfully. I feel it is best to isolate the power of the smoke pump from the receiver of the model.
