switch assignment
switch assignment
Hello,
I am new to JR and now have a couple of 10 X's. I am wondering if someone could give me a brief overview of how to assign the side slider switches to different channels. ie. I have a BVM bandit and would like to put the speed board on the left slider and then assign the right slider to the brake servo. I have heard that any switch could be assigned to any function/channel on these radios. Any suggestions would be helpful.
MACE
MACE
RE: switch assignment
To assign the left slider to a function for example, you will use an origin mix which is described in the manual. To do this, set up a flap to the channel that you want the function active on, then press the page key twice, then then press SEL under MASTER until it says ORIG. Then press page back to the main mix screen and set the rates as needed.
