10X Heli to Aircaft Conversion
My Feedback: (33)
TX
Is there any way to convert a 10X Heli transmitter to an aircraft transmitter? Can JR install a new chip or somehow re-program the transmitter?
Hose A
Hose A
Banned
My Feedback: (10)
WI
RE: 10X Heli to Aircaft Conversion
that radio has the programing in it. You need to change it in the radio. If you are referring to the throttle control you can add a spring clip to make it ratchet.
None whatsoever. The Processor chip has to be replaced, new connectors fitted and cables moved around on the PCB.
The only way to convert is by installing a new processor pcb for Aircraft mode, & replacing some of the switches.
