6102 programing question for micro-jet
Danny, I need some help programming my 6201. I have a Multiplex Micro-Jet electric plane. It uses elevons. This plane likes to roll to the left when launched due to the engine torque. What I would like to do is program a switch to give a little more up elevator on the right side to off set the torque of the engine then once in the air I would like to flip a switch to then make both elevons the same setting. I think someone said this is adding some reflex. Where in the manual would I look to do something like this or could you post the info here?
Mike
Mike
RE: 6102 programing question for micro-jet
I don't see a way to program the mixes to only affect one side. You could though set up an aileron to aileron mix, assign it to the switch of your choice, enter the maximum offset in either direction (press and hold either the increase or decrease while the arrow points to offset), and enter a percentage to give right aileron.
Why not just adjust the thrust? Wouldn't that be a little easier
than trying to mix everything, and trying to be quick thumbed!!
Just a thought
Regard's
Just a thought
Regard's
