9303 and 8103 info compatible and elevator mix ?
My Feedback: (17)
KY
i want to transfer the info for my planes from my 8103 to my 9303 things like servo travel and mix percentages manually if i put the same numbers from the 8103 to the 9303 will the plane fly like it always has with the old 8103? for instance will 14 sub travel on the 8103 be the same for the same plane that I'm switching over to be the same as 14 sub travel on the 9303 and ever thing works the same
also I'm having trouble getting it to mix the channels for the elevators whats the procedures for that
i have flaperons activated and it wont let me mate another channel or is it like the 8103 where you use mix 5 or 6 and mix ele to aux
RE: 9303 and 8103 info compatible and elevator mix ?
Using the same values will get you close, though there may be some variances, so it may take a bit of dialing.
To set up dual elevator (or any other dual function for that matter) begin by going to the device select function, and inhibit the channel you want to use for the second channel. Then go to the wing type function and activate the "dual" function of your choice on the channel of your choice.
