Function 14 Question - 10X
My Feedback: (198)
If I change Function 14 - Trace Rate, obviously the "feel" of expo and total travels will be different. My question is this ... If I change Trace Rate by "5%", will a corresponding 5% change in other functions related to travels be all that's needed?
Example - pitch or roll mix...since Trace has changed, will the same "percent" of change be needed in those functions?
I know the real answer is to "go fly it", but I'd like to know if there is a proportional relationship within the increments of the Trace Rate, Expo, and other Mix functions....
RE: Function 14 Question - 10X
I would say 5% or less change in the other functions in your example. Unfortunetely the only real way to answer this question is the fly it, as each model will be different in how they react to the change.
