Dual Rate Switch Assignment
My Feedback: (33)
RE: Dual Rate Switch Assignment
I wish that was possible also , if it is not could you tell us if the new 9 is capable of this? Not trying to hijack your thread just interested also .
Chad
Chad
The only way to set this up would be to set up 2-3 mixes, a mix for each channel, assigned to the same switch, where you mix the channel to itself, and make the percentages a negative value to take away throw. It will have to be a different switch than the dual rate switches.
Hey Danny:
I have done as you suggested about assigning dual rates to one switch;however, what happens to the exponential settings when you do this ?
hal
hal
