JR 9303 Programming Guide
NV
Danny... Have you guys developed a programming guide such as you have for the 8103? This will be for a dual elevator and dual aileron setup. I've e-mailed HH customer support and haven't heard anything from them.
RE: JR 9303 Programming Guide
At this time, there isn't one. In the 9303 these functions are simply activated and is covered in the manual in how to set them up so there isn't as much of a need for a guide like there was for the 8103.
NV
I've tried to read the manual and apply the dual elevator set up. With the 8103, you needed a program mix to activate the dual elevators and create another mix to inhibit the Aux 2 knob. Do you have to do any inhibiting with the 9103?
You have to disable a channel in device select before the channel is available in wing type. So the procedure for setting up dual elevator for example would be to go to device select, inhibit the channel you want to use, then go to wing type and turn on dual elevator. No other steps are required, no mixing, etc.
