JR XP642 Ailevator
MO
JR XP642 Ailevator
Danny does the JR XP642 have the Ailevator function or will I have to buy a servo reversing harness?? If it does how do I set it up? Thanks for your help.
RE: JR XP642 Ailevator
I assume you are refering to delta or elevons for a flying wing or delta plane of some type? If so, yes, the 642 has this function. To access this, press and hold the mode and channel keys together and turn the system on. Then press the mode key until you see an option that says MIX WNG. Press the + key until this says MIX DLT ON. That should be it.
MO
Danny, I guess I could have done a better job explaining it. I have a .46 U-Can-Do aircraft and it has two elevator servo's. One mounted on each side of the fuselage in front of the horizontal stab. Both servos have to move together unlike the aileron's?? Maybe this helps, the aircraft instruction manual said if I don't have this feature on the radio I have to purchase a servo reversing harness? Thanks for your help
Terry
Terry
