Dual Aileron Setup
Dual Aileron Setup
I have a JR X-378 radio and I can't get my aile servos to work together. I have chosen the flaperon type wing. I have one servo in ch 2 and the other in ch 6. The ch 6 servo is being controlled by the gear switch. I can't figure out how to make it work with the other aile servo.
RE: Dual Aileron Setup
To do this, all you need to do is activate flaperons. I would also recommend going to the Flap LEVER function and inhibit it by pressing clear. You must have a mix set up to make the gear switch control the flaps. Go through your program mixes and make sure there isn't a mix set up that is affecting your set up.
