9303 Sailplane Switch Names
NC
Danny
Can you post a DIAGRAM for the 9303 that shows the proper names for the various switches that are used in programming the sailplane version? In my initial "playing around" with the 9303, it appears that the labelled AUX 4 is really on the Mix Switch and the GEAR switch is really the BUTTERFLY switch. I am confused by the various uses of the switches and plan to label my 9303 for the sailplane switch pattern. Can you help this old fart?
Leon
Leon
RE: 9303 Sailplane Switch Names
I do not have a diagram or anything else I can post here. Aux 4 in glider mode is the long flat switch on the back, upper right side. The gear switch is the butterfly switch in glider mode.
