10X ???s
My Feedback: (25)
AR
10X ???s
Will the 10X limit the total servo travel no matter what you have mixed into the channel.
For example... I want my ailerons to be up as spoilers. When flying on 3D rates, will full aileron deflection drive the up-going aileron past the 3D aileron control throw or limit it to said throw?
Also... when was last revision to the 10X software or TX in general?
Jason
Jason
RE: 10X ???s
There hasn't ever been any revisions on the 10X since its introduction, which if memory serves is around 4-5 years ago.
No, the 10X will not limit the throw, except in built in mixing such as delta or elevon mixing. You can drive the servo to its maximum end point (possibly reaching your bevels and overloading the servo) if care is not taken in the set up.
My Feedback: (25)
AR
RE: 10X ???s
Well... that's no good.
My royal evo would limit the throws, but I really wanted expo per phase. I haven't found a radio that will do what I want!!!
Hopefully the matchboxes will limit the throw... time to go do a little testing.
RE: 10X ???s
If the bevel and mechanical set up is sufficient to allow the throw, often this will not cause any issues. The matchbox will not really do anything above what the radio system is capable of in this aspect. Yes, you can cut throw with a matchbox, but you can do this with travel adjust as well.
My Feedback: (25)
AR
RE: 10X ???s
Righto...
... it's just as well... it forces the thinking man to get the most mechanical advantage possible. It just prevents the use of some types of servo arms, such as the Air Wild arms (sit low... nut may strike case) or possibly the nelson arms (supposed to put link under the arm).
