THROTTLE KILL
RE: THROTTLE KILL
Yes, set up a throttle to throttle program mix, press page, select the switch you want it on, press page twice, put the switch in the position you want it on, and enter negative percentages to take away throw in the amount desired.
TN
RE: THROTTLE KILL
Danny, I setup my 9303 with the thro thro mix to kill the engine, but i cannot figure out how to assign it to the train button. I want some sort of spring loaded switch as opposed to the manual flip switches. Could it also be programmed onto the left side slider switch If I wanted?
Anthony
Accaptain
Anthony
Accaptain
RE: THROTTLE KILL
Danny, I used the push button as the throttle kill switch and it acts like a push on push off switch. is there a way to make it act like a momentary switch?
