JR X2610 Tx mixing
JR X2610 Tx mixing
Can anyone out there help with the following mixing setup on the JR X2610 Tx ? :
Right hand Tx toggle switch to lower flaps to, say +/- 15 degrees, then followed by left hand Tx switch to to lower flaps from the previously set 15 degrees to say +/- 30. In other words I would like to use the two toggle switches to progressively lower flaps. I can't fathom the master/slave configuration and offset.
Thanks in advance
Ron
Thanks in advance
Ron
