Where is the Trim Offset Memory on my XP8103?
OR
I was trying to use the Trim Offset Memory function on my XP8103 and could not fine it on any of the menus. Where is it? I followed the instructions in the manual.
I pressed the "UP" and "DN" buttons simultaneously and then the "DN" and "SELECT" buttons simultaneously. The Trim OFST is not available.
Is there something I'm overlooking?
FL
If you have an 8103 with digital trims, there is no trim memory function. The trim you set on each model stays with that model.
(Yes I know what it says in the manual )
