Programming?
My Feedback: (27)
Programming?
Danny,
Before submitting this thread, i looked around to see if anyone was having a similar problem. SigFazer seeems to have an identical problem. What am i doing wrong? I set up a 662 and a 10S on seperate aircraft for flaperons. Now, everything is working, except the ailerons. They are going in the opposite direction that i want them to. It is like everything is reversed. When i move the stick to the left, the left aileron does go up, but the right aileron moves a greater distance than the left(going down). And vice versa. I don't understand what i am doing wrong. HELP?
Ron
Ron
Programming?
When you move the stick to the left, the left aileron should go up. Have you deactivated the flap switch? If not, one servo is likely running out of travel and stopping. Set up a mix, channel 6 to 6, and make the percentage -100% on both sides. If this has already been taken care of, it is likely that the reason the aileron going down moves further than up is a mechanical differential set up in the linkages. You can either adjust the linkages to cure this, or you can use the travel adjust or the differential feature in the transmitter.
