JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR X 388S Tx False low voltage indication on LCD
Old 02-16-2007, 07:26 PM
maxjanet
Default JR X 388S Tx False low voltage indication on LCD
Hi,
We have a JR X388S TX which has started to show an under reading voltage display of the fully charged set. The LCD display on the set shows a reading which is about 1 volt lower than the measured voltage of the TX battery pack. Can you please give me some info on how to find and fix the faulty component on the circuit board (voltage devider or ic). It may not be pactical to fix this set if the the fault is in a large multi pin IC.
Regards
Max
Old 02-16-2007, 07:33 PM
Mac_Man_UK
Mac_Man_UK's Avatar
Default RE: JR X 388S Tx False low voltage indication on LCD
Its just a calibration issue.
