DX3 has barely any steering to the right
Hey... need a bit of help with my Spektrum DX3 please.
Just got it used off e-bay... and in good shape, and I'm bench testing the receivers & servos etc.... and have next to no steering action to the right. Left has lots of movement... but there is almost none to the right on the steering servo. I tried my throttle servo (which works great in the throttle/brake slot) and it does the same thing. I tried my 2nd SR3000 receiver and it does the same thing. I reset the model so all the settings are back to factory. I even tried the steering trim.... barely any change.
Any ideas before I blame the transmitter and get all mad at the e-bayer I bought it from?
Thanks in advance!
Thanks in advance!
My Feedback: (35)
KY
RE: DX3 has barely any steering to the right
The first thing I would do is remove the arms off of the servos and see if you have full movement. The new radio may have centered the servos in a different position. Then go into the program and make sure you have 100% in both directions. Dennis
ORIGINAL: DadsToysBG
If I reverse the settings.... the servo works the opposite, but when the steering wheel is turned right... little movement to the left on the servo. I'm thinking the transmitter has a problem in the wheel electrics to the right side.
Check your travel adjust settings to be sure you don't have the travel adjust cut back. Also try going to a clear model, do a reset of the programming, and retry.
ORIGINAL: dsnyder
If all else fails... who do I contact to send it in for servicing... and specific person or just a general call?
Thanks!
You can call product support at 877-504-0233 for assistance. Information for sending equipment in can be found on the service center checklist.
http://www.horizonhobby.com/Support/...t/Default.aspx
ORIGINAL: dsnyder
Thanks for the help!
