JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
DX7 Flap on Boomerang Intro
Old 01-26-2008, 07:31 PM
hutt
Default DX7 Flap on Boomerang Intro
Hi Danny
The Boomerang has a single central flap between the twin booms.
I would like to use the 3 position switch to operate the flap.
I would also like to mix in some down elevator with the flap.
If I plug the flap servo into Aux 2 how can I ajust it with the "Flap System" menu, this menu only seems to move the ailerons as flaps.
Many Thanks
Old 01-26-2008, 09:20 PM
rcguy!
My Feedback: (69)
rcguy!'s Avatar
Default RE: DX7 Flap on Boomerang Intro
Plug it into AUX1.
Dave
Old 01-27-2008, 05:54 AM
hutt
The left aileron is in AUX 1 or can that be moved to another port ?
Old 01-28-2008, 09:50 AM
dsnyder
dsnyder's Avatar
In order to use the flap channel with the flap system, you will need to turn flaperon off, plug the flap servo into aux 1, then use aux 2 for your second aileron channel, first by inhibiting aux 2 in the input/switch select function, then setting up an aileron to aux 2 program mix, and set the rates to 100% in both directions.
Old 01-28-2008, 04:16 PM
hutt
Hi Danny
All is now working perfectly, many thanks.
Old 01-29-2008, 09:27 AM
dsnyder
dsnyder's Avatar
Great to hear! Enjoy!
