KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
140G default settings ?
Old 01-27-2013 | 11:33 PM
Default 140G default settings ?
Could i be supplied the140G default settings for my turbine .
Old 01-29-2013 | 02:50 AM
Default RE: 140G default settings ?
no info ?</p>
Old 01-30-2013 | 06:24 PM
marquisvns's Avatar
You could try these:
Menu Start :
Auto +1
Pump Start Ramp 10
Glow Power 7.2V
Low Batt 6.0V
Start Power Ignit 60
Starter Power Fuel Ramp 150
RPM 100% Starter 17000
RPM Stop 19000
RPM Reconnect 18000
RPM Ignition 3000
Pump PW Ignition 18
Engine Min Flow 80%
EGT End 72°C
RPM Preheat K 5000
RPM Fuel Ramp 9000
Preheat Fuel 30% for Kero, 15% for Diesel
Ignit Time Out 27s
Start Mode AUTO COR
Menu Run :
Full Power 122000
Idle SPeed 33000
Stop Peed 15000
Start Min 80°c
Max temp 840°C
ACC DELAY 3
DEC DELAY 2
Stability Delay 100
Pump Limit 448
Old 01-30-2013 | 07:48 PM
thankyou for those .
Old 01-30-2013 | 09:45 PM
marquisvns's Avatar
no problem, you could also get in touch your dealer or KingTech Australia, Ken Mollison.
Barry
Old 01-30-2013 | 11:50 PM
yeahr Ken is all good he has helped me when engine was first fired up . Just wanted base settings when new . Thanks ..
