KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
Failsafe message on K-100
Old 07-06-2014 | 05:51 AM
redbiscuits's Avatar
Default Failsafe message on K-100
On the maiden flight of my Turbinator it got too slow on approach and stalled about 30 foot off the deck. The person doing the maiden for me immediately shut the turbine down, as it pancaked in into some tall grass at the end of the runway. I didn't have my GSU on me when we got to the plane, and in the panic of the incident, instead of carrying the plane back to the pitts with the rx still on, I shut off the rx before the walk of shame.
When I plugged the GSU into the ECU, it said the last shut down was a "failsafe" at 388C, 56000 RPM, Pw116
Is it showing a "failsafe" message because I shut off the receiver before it competed the cool-down cycle or did the turbine shut down causing the situation in the first place? The pilot and I thought we heard the turbine running the whole time, so this is kind of confusing me.
Gary
Old 07-24-2014 | 07:57 AM
if your helper shut it down (by lowering trim or by kill engine switch),it should display useroff.
extracted from manual:
Diagnosis messages:
UserOff: The engine has been shut down because it has received the shut down
command from the transmitter.
FailSafe: The engine has been shut down because of loss of signal from the
transmitter. Once Ecu detects a loss or invalid RC signal for over 0.5 second, it sets
engine power to idle, and if after another 1.5 seconds a valid signal is still not
received the engine is shut down.
LowRPM: The engine has been shut down because the RPM has dropped below a
minimum. Cause could be lack of fuel, air bubbles, problem with the batteries, or
defective RPM sensor.
FlameOut: The engine has been shut down because the temperature has dropped
below the minimum of (100ºC). (If not shut down manually, usually a thermocouple
failure).
RCPwFail: Lack of power from the radio receiver.
