Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > KingTech Turbines International
Does elevation change startup parameters? >
KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
Old 09-16-2015 | 11:27 AM
Default Does elevation change startup parameters?
Hey guys, I have a K-180G and the engine has only been run in Phoenix, AZ where the elevation is about 1500 feet msl. I recently moved to Salt Lake City, UT and the elevation of the flying field is about 4500. Is there anything I need to change in the startup or running parameters off the bat before I start this jet up? Thanks
Steven
Old 09-21-2015 | 12:19 PM
Anyone?
Old 09-21-2015 | 02:19 PM
gunradd's Avatar
My Feedback: (9)
Well I would try a start but be alert for flames. If it starts hot then shut it down and let it cool off. With thinner air I would say you might need to lean out the start some by turning down the preheat fuel. But you might find its good to go.
Old 09-22-2015 | 02:15 PM
FenderBean's Avatar
I don't think that high will effect to much but you may be a little richer at those alts since the air will be thinner to you fuel ratio
Old 09-23-2015 | 03:40 PM
Both of you were right as it was a little rich. I adjusted a few parameters and its starting and running like a champ. Thanks to you both.
