 Drawings/plan for DC-3 >
Old 01-03-2011 | 02:51 PM
Default Drawings/plan for DC-3
Hi Guys,
Can anyone please point me in the right direction for drawings/plans for a DC-3 kit with an all-up weight of max. 6-7kg?
Any assistance is highly appreciated.
Happy New Year to all of You!
Old 01-07-2011 | 06:36 AM
Default RE: Drawings/plan for DC-3
Anyone ??
Old 01-07-2011 | 08:41 AM
vicarh's Avatar
Godhelper.
Go to www.rcscalebuilder.com and post the question.
Old 01-07-2011 | 01:15 PM
LargeScale88's Avatar
The Top Flite DC-3 is perfect. Its final weight is about 10-15 pounds (about 6-7kg). It comes as a full kit.
Follow the link here:
http://www3.towerhobbies.com/cgi-bin...XHU97&P=ML
Hope this helps!
Jason
Old 01-07-2011 | 01:16 PM
My bad, the Top Flite DC-3 has a weight range of 8-10 pounds. Well in your range.
Jason
Old 01-07-2011 | 01:54 PM
Bill Diedrich's Avatar
A kilogram is 2.2 pounds 6kg= 13.2 lbs 7 kg= 15.4 lbs
Old 01-07-2011 | 02:16 PM
ORIGINAL: Bill Diedrich
I was saying well in his range as not way above and not way below. Its below by some pounds, but not much.
Old 01-07-2011 | 03:46 PM
I once found a digitized copy of a 1940s blue print buried deep on the internet. Came across it by accident, and once I realized it had all the actual dimensions and cross sections, I built a static 45” ws model – it was my first build after 30+ years. I’m not sure if the reproduction quality is good enough for a flying model, but the drawings couldn’t hurt. I’ll look for them. Keep looking, there’s a lot of DC-3 stuff out there, not much on the DC-4 though.
Like I said, it was my first build after 30+ years, when I cut the windows in I came across a stringer – didn’t plan for that!
ID:	1543765   Click image for larger version
Old 01-12-2011 | 10:13 AM
Hi Guys,
Thanks a lot for Your info!
@ Jason :Spot on - thx m8
