 Metallic Paint and Radio Interference >
Old 03-22-2011 | 06:24 AM
Banned
Default RE: Metallic Paint and Radio Interference
"Perhaps you also are using much higher power like I used to with about 5 watts in the antenna."
No: Just like it came right out of the box.
"Beside having the covering in sectons likely insulated from each other by the glue on overlaps, "
I doubt that. Think capacitors. Large capacity capacitors.
Les
Old 03-22-2011 | 11:32 AM
Zor
Banned
ORIGINAL: LesUyeda
Zor
lesUyeda
This implies that it was a commercially produced sytem.
I tought that the market for RC radios on the 6 meter band would be very small or non-existant.
I figured you had made your own 6 meter radio gear like I did.
Zor
Les
The point I was considering is that there is little chance that some of the covering would resonate on the 6 meter band and that any shielding would be quite low if any.
I am not saying that resonance is needed for having an effective shield. I hope people understand how and why conductive material acts as shields and how and why conductive materials affect the directivity characteristics of antennas.
Thanks for your outlook.
Regards de Zor
Old 03-23-2011 | 06:03 AM
Banned
"Perhaps you also are using much higher power like I used to with about 5 watts in the antenna. "
That is a NO. Just like it was, right out of the box.
Les
Old 03-24-2011 | 05:24 PM
Zor, in response to your question, Yes the 2.4 RX was inside the
plane and never any problem with 2.4,
Bob
Old 03-24-2011 | 05:48 PM
Zor
Banned
ORIGINAL: goatnick
Bob
Thanks Bob.
That info may be useful to many modelers.
Zor
Old 03-24-2011 | 07:04 PM
  #31
All Day Dan's Avatar
Much to my pleasant surprise, I just got a response from Futaba. The response was non technical without the benefit of any testing or data collection. It stated that they asked around and that the consensus was that the metallic paint was not a threat to the reception. Well, that's about it and coincides with what the guys on this thread proved by practice. Thanks a lot to you all. I'll keep the results in mind for my next plane. Dan.
