1:12 scale Cracker Jack?
I am curious if anyone has seenDennis Tapsfield's1:3 scale Cracker Jack (112" span) scaled down to 1:12 scale (28" span). I would like to build this model at the smaller size, but am only able to find the original plans from RCM (featured in issue 10-85). Due to the size I imagine the scaling would need to be done by hand, unless someone has access to a very large scanner/copier, and don't feel I am up to the task.
Lots of printers and copy shops that handle blueprints for engineers can scan these large plans into an Akrobat pdf file. Then you can print out any size you want.
Tom
Tom
