Die cut Kit question
Hey guys,
The reason I ask, While building a Pica Deullist (lazer cut) I had called around and I think it was Nick Zeroli, or a representative of and he explained that I should be lightly sanding the edges of a lazer cut part where ever gluing. He explained that it was important and that the CA Glue could not do its job when there is a burnt edge.
While I was building last night (patriot, die cut kit) I was a bit concerned about some of the edges, I think I heard someone say the crushing effect of the die. but it was very minor.
so I thought that I would ask to see if, Like the lazer cut parts, do a light, light sanding.
With the die cut, I have had no issue with the glue working.
ONly reason is for glueing purposes, especially when sheeting, ie the ribs need to be lightly sanded so that the ca can properly wick.
I really would have agreed with you but after getting a real talking to and a good explanation I had to buy into the idea that it could make a real difference in the quality of your glued joints and strength as well.
Anyway, got to go and thank you guys for the help.
