***CUB BROTHERHOOD***
#1701
I noticed something last night about the SIG 1/5th kit. Everything on it is pretty close to scale, dimensions, etc, however... the cowl is no where near scale like, it doesn't even look like a Cub cowl. The GP ARF cowl looks mire scale like, even though the entire plane is no where near scale.
#1702
You would think since it is modeled after the Clipped wing that the cowl would also be scale. Its too wide at the bottom. Maybe they did it that way to accommodate more engine choices.
#1703
I believe Sig's 1/5 - 1/4 cub kits are "stand off scale" which is mostly physical dimensions represent the full size; the proportions are not exact... then there's some fudge factor involved due to design elements, building / assembly methods, and construction materials used... on the 1/4 cub, all the placements like the landing gear, wing strut mounts, are close to the full size but not exact... the fuselage width probably has an affect on how the cowl take its form... in order for the cowl to be scale, the rest of the aircraft would have to follow, or somethings not going to look right; the proportions would be way off.
John M,
John M,
#1705
The GP Arf of the same "scale" that my friend has is pretty close as far as dimensions. The fuse is the same width and height as the SIG, and the cowl will fit the SIG, it looks more like the real Cub cowl than the Sig one does, that is the only piece out of place on the SIG. The SIG cowl is wider at the nose, looks more like the Super Cub cowl. The GP cowl has the chin that is quite apparent on the real Cub. Here are the two planes, you can see the differences, the GP looks a lot closer to the real one.
http://www.sigplanes.com/SIG-Anniver...-Kit_p_71.html
http://www.greatplanes.com/airplanes/gpma1311b-lg.jpg
#1706
You can get a set of Paul Matt drawings (in one of his two albums (books), too. That's what I did when I built my PA-12 Super Cruiser as modified from SIG 1/6 Cub kit. I have the capabilities to make more glass cowls for it if anyone is interested in the purchase.
#1707
John M,
#1710
Does anyone happen to know the rough dimensions of a 1/6 scale dummy engine? I know it's only the lil one, but it just doesn't look like a cub without the cylinder heads and eyebrows on the side of the cowl. I'm basically at least looking for the dimensions across the cylinder heads. Full scale dimensions will work. Also, the diameter of exhaust tubes. Thanks, Steve.
#1711
I don't know the sizes but you can't beat one of these. http://www.topnotchkits.com/index_files/TN_Kit11.htm
#1712
#1713
In that case Steve the Cubman offers up the drawings,http://thecubden.org/thecubden/wp-co...ontinental.pdf, just resize for your scale.
My 1/4 scale measures 42mm center of the heads, 1/5 scale should be 33.5mm
#1716
#1719
#1724
#1725
Making some progress with the door / window re-enforcement... no pics yet, as I'm still digging out all the soft balsa doubles across the top of the cabane's... I have the forward window stays removed, as well as the window rear pillars at F-6... I forgot that the two wing locating dowels penetrated into the cabin blocks, so I've updated my drawing I did earlier to better reflect my intentions... so far it looks like its going to work out just as I intended... with the forward window pillars removed, its not too difficult to run a 1/16 drill bit up into the soft cabin blocks along the face of F-5 to create a slot for the brass tabs to slide in place... I also lengthen the brass tabs 1/4 of and inch, so they are now 3/8" x 1 3/4" x .067 ; 3/16 music wire bent to re-enforce the upper window frames ... I also soldered 2, 4-40 nuts to the brass tabs... then slid the tabs in place and ran the screws in from the wing side; screws are counter sunk flush to F-5 (wing side)... this will be much easier to do as you are building the fuselage, rather than after its completed, but not impossible, just takes some fiddling... once I have it completed, and before I glue everything in place... I'll take it apart and takes some pic's of each step of the final assemble.
John M,
John M,
Last edited by John_M_; 02-16-2014 at 03:34 PM. Reason: Changed Brass Tab Dimensions
