***CUB BROTHERHOOD***
#2126
acdii, how are you going to paint yours?
I used sig koverall for the first time and just went with rattle can paint, but I forgot to use a primer and it is relatively easy to scratch off
I actually had a bugger of a time building this plane I'm starting to hate it, several times I nearly smashed it against the wall.
It's an old pilot ok models kit, glad they don't make them anymore, I normally love making kits and can't wait to get building, but this one has tried my patience.
I'll probably smash it on maiden...... bloody thing!
I'm tempted to kamakazee it into the ground, then I'll buy a sig kit.
Going the full Dope route. Red White and Blue paint scheme. I got one coat of white on the stab and elevators with a brush, doesnt look too bad, so will see how the second coat goes, before I decide if I want to go with brushing, or just spray it and build some clouds.
#2127
Did you use primer? I didn't and the paint just scratches off the dope, I put a couple of clear coates on it now to see if that holds it together.
I'm just going to fly it the way it is.
#2129
John...I'm probably gonna show my ignorance here, but oh well.
Is thing that for real, or PhotoBunk? It looks like 4-stroke jugs on a 2-stroke crankcase to me... The Pegasus 240 & 320 look like this:
I don't see a gearbox for the camshaft on the one you have there; unless they've completely redesigned and are driving the camshaft from the back end of the crank...
[EDIT]
Yup... there it is; my ignorance showing. Looks like it's based on the FT-300 Gemini platform, not the original Pegasus platform. D'OH!
[/EDIT]
mnem
Arrrrou...?
[EDIT]
[/EDIT]
mnem
Arrrrou...?
#2131
mnem, its photoshop... Its two FT-300's in tandem... if you ever have seen a FT-300, its a monster; twice the size of an FT-160.. but you're right about the cam drive gear... on a twin setup, its behind the back plate, but on a four cylinder setup, I would assume they would need an additional drive gear up front as well.
It was all in fun... if there every were a FF600, it would make that FF240 / 320 look small... and the FF600 would weigh in at just over eight pounds, great for balancing a tail heavy setup
.John M,
.John M,
#2132
#2135
My Feedback: (9)
NC
#2136
Hey, are you talking about the Pilot 1/4 scale J-3? I have been working on one on and off for a couple of years. Very scale kit. What kind of trouble are you running into on yours? I'm just very curious, as I love Pilot kit's, and have been collecting them for years. I think you are the first person I have ever heard that said they did not like Pilot kits. She will be very scale when you get done with her, I can guarantee that for sure.
Maybe I'm a just a spaz, I've always loved every other kit, just not this one.
#2137
LoL... yeah, just to put things in perspective... a O.S. GF40 (40cc) 4 stoke turning a 18-8 prop, produces approximately 17 lbs of static trust, and with a 20x-8, about 19 lbs static thrust... just about right for good vertical performance for a 16-20 lb aircraft... if there were a FF600, it would be just about right for a 33-40% cub weighing in at 35-45 lbs;in my opinion anyway... I've seen a balsaUSA 1/3 cub with a FT-300, and although it flew well (very scale like) it didn't have quite the vertical performance that I would like to see... I've even started second guessing this FT160 I have in this 1/4 scale cub, that will probably be close to 20-21 lbs when I'm finished with it.
I didn't do it, my sister's husband did it for me... would be nice to have though.
John M,
John M,
#2138
.John M,
.John M,
My first reaction was as I said; it didn't look like a Pegasus to me. I saw one for sale at a swap meet (It was probably a 240) a few years ago, and I was just in awe of the craftsmanship and engineering of the thing; even old and abused and covered in oil and grime it sang to me. I went and did some research on it and read about it and the 320; simply beautiful; the 2-piece split crank as they did it really fascinated me. But I wasn't doing airplanes; I was knee-deep in my T-Rex 450s, so I just filed it away in the back of my brain.
I've designed and fabricated a couple small engines as machine-shop projects, so I have a keen appreciation for the engineering involved; I used to race and tune 2-cycle motocross bikes as a youth and cut/ported my own pistons/sleeves, even designed some shaped-charge heads and multiple reed-valve manifolds.
BUT... knowing that, I knew it was possible... and imagined that in an age of 3D-printed molds, a limited-production behemoth like that would have to be possible, and somewhere, there's someone with the money to burn to make it happen. If there weren't, Conley would have gone out of business ages ago.
But... I'll be the first to admit I have very little experience with model airplane engines, aside from the castor oil spraying little b@stards I used to abuse as a kid. Those were more like the old 50 FSR I have on the shelf right now; I just can't make myself rebuild and put it in that 40-size Pawnee you see in the background of my Easter pic. I've gotten lazy in my old age; just the thought of all that mess fills me with dread. I'm gonna put a gasoline engine in it if it sits for 3 years waiting. Maybe by then I'll actually know how to fly.
mnem
" Some pilots fly by the seat of their pants; I fly by the skin of my teeth."
#2139
NH
New to thread. Count me in on the "Brotherhood".
presently have 2 1/4 scale and one 1/5 scale Cubs.
rebuilding an old (read 1980 vintage) 1/3 scale casualty.
need info on proper dihedral please.
thanks.
thanks.
#2140
Sorry to be deceptive mnem... I was just playing... I'd like to see some 4 stoke engines in larger capacities like they do with the 2 strokes... our local HS has one of the OS FT300... its just amazing the quality of the workmanship... if you really like model engines, take a look at the Kavan 50 mk II... that's another fine piece of workmanship; has an oil pump and sump.
My farther and his farther use to do the same regarding dirt track racing... modified 2 stroke engines; porting / tuned exhaust, etc... hiding everything under cloth until race time so the competition couldn't see what they were up against... that was back in the day they use benzene in racing fuel.
Anyway I think we have strayed off topic again... sorry guys!!
John M,
John M,
#2142
Wow, well there's your half scale power plant acdii... supercharged to boot..
lol supero8, its never what I want; its either marginal, or way overboard... 250cc 4 stroke in deed, lol; nice looking engine though... would be nice if they would come out with something in the 70-100cc 4 stroke range, then I'll jump on a 1/3 scale like a wild cat on its prey.
John M,
John M,
#2144
MN
I have a Dave Patrick Super Cub with a G-23 zenoah in it and it has ample power and is as dependable a motor as is out there. Mine has the magneto ignition because the model needed the nose weight and that is something to cinside when you are choosing your motor.
#2145
Hi rocky... right, but the G-23 zenoah is a 2 stroke gasser... in a 4 stroke, you would need 35-40cc to equal similar performance as the zenoah 2 stroke... with a single cylinder 2 stroke engine, you get a power stroke every revolution of the crankshaft... with a single cylinder 4 stroke, you get a power stroke every two revolutions of the crankshaft... plus a 2 stroke turns the prop at a higher rpm... then there's the argument, that a propeller is more efficient turning at a slower speed with more torque from the 4 strokes.. but when you start scaling propellers down for models, their efficiency changes with the scale factor... can you imagine a full sized piper cub engine turning its propeller at 7,000-10,000 rpm like some o theses model 2 stokes turn at... what an airshow that would be !!
BTW Rocky, what does your Dave Patrick Super Cub weigh in at?... I believe its basically the same as the Hanger9 1/4 super cub (based on the DP design).
John M,
John M,
#2146
Super08 - that DA250 is dead sexy, man. A huffed boxer twin... I wanna stick that on a go-Kart.
I'm sure we've all seen pix and movies of the Conley V8 and the Stinger Supercharged V8 based on it; these are now really mass-production toys rather than the amazing object of mechanical craftsmanship that Conley's T-Bucket was when i first saw it featured in a magazine as a kid.
Anyways... if you haven't seen it, The Internet Craftsmanship Museum is an awesome collection of pretty much every sort of quality craftmanship you can imagine, including some astounding metal aircraft and boat models, and it is also home to a very nice photo review of the Paul Knapp Model Engine Collection, including some radials that are simply gorgeous.
mnem
*Sigh*
mnem
*Sigh*
#2149
My Feedback: (50)
#1 Cub Man - Charles Brooks
#2 Minn Flyer - Mike B.
#3 acerc - Robert R
#4 Arup -
#5 Frequent Flyer -
#6 bikerbc -
#7 GAP RCU -
#8 rafeeki -
#9 Scirocco 14 - Mark
#10 Lins - Lindsey G
#11 CK1 – Chris
#12 Jaybird –
#13 heritageman -
#14 Live Wire - Larry K
#15 Saito18 –
#16 davidgeorge212 –
#17 WacoNut –Anthony
#18 raydar –
#19 no1isnormal –
#20 JH313 –
#21 JNorton – John
#22 FJRrider –
#23 lovetoflyguy – PJ
#24 Edwin – Edwin
#25 Lavell – Lavell
#26 crash bandicoute
#27 do335a –
#28 fred985
#29 Pa-18cub150 –
#30 cessna579 –
#31 cubcrasher –
#32 mac1va –
#33 morganflyboy –
#34 Steve Landron –
#35 mintie –
#36 Gordie M –
#37 extra-nut –
#38 snowball –
#39 eastkurt - Kurt
#40 JerryM –
#41 rcavi8or –
#42 meanrc –
#43 Rc Overkill –
#44 oldiron410 –
#45 Hill202 –
#46 weathervane – Andrew
#47 SunDevilPilot –
#48 iflyj3 – Dan
#49 gluemaster –
#50 EddieC –
#51 CanDo – Les
#52 dabigboy – Matt
#53 [email protected] –
#54 woodworm –
#55 skipb
#56 mrdhub – Dan
#57 Homer712
#58 scaleman57 –
#60 psheffield
#61 quiltsfly
#62 G.Barber
#63 bobbailey
#64 scflyboy
#65 Cub Flyer Fresno
#66 FILE IFR - Mike T
#67 talob – Mike
#68 Lowvoltage – Joe
#70 Glyder – Chuck
#71 smkrclfyer –
#72 jeffEE
#73 GW –
#74 lever02
#75 AB Bob – Bob
#76 rede2fly –
#77 Barn-E-Stormer
#78 Ray S. –Ray
#79 Daniel-EL
#80 ExcaliburIII – Richard Longfellow
#81 jrb1 -
#82 on_your_six –
#83 BGCombs
#84 RevGQ
#85 jkr_1100
#86 Dope Fiend
#87 paero-RCU
#88 .50cal
#89 mrshea - Phil
#90 Cougar-RCU
#91 glenladen
#92 cublover
#93 lowbubba
#94 steve
#95 Gray Beard
#96 roaddog2
#97 biam
#98 rcpilotaviator
#99 funtana1
#100 rcavi8or
#101 GPutt33
#102 actionjackson
#103 sj3cub
#104 dreamwever
#105 phatbob02
#106 igoren
#107 N1EDM
#108 mrwad – Don
#109 dirtrod – Ty
#110 HawkI
#111 redkav
#112 GerKonig _Gerry
#113 SCOTT42
#114 5blue
#115 crazystick
#116 3[SUP]rd [/SUP]time Richard
#117 chevyman962000
#118 Mrj3cub
#119 Oldflyer2
#120 rogergh
#121 TEAMERICA
#122 cannonball200
#123 TripleDeucer
#124 tenspeed59 – Mark
#125 rcjunky67 – Robert
#126 VincentJ
#127 nalby
#128 fcf
#129 malitape
#130 sirzepp
#131 rmpRmP
#132 Rv7garage
#133 pt19 flyer
#134 JohnFH
#135 ahgoodman
#136 skyraider71
#137 Planejaw
#138 rc airplane nut
#139 Stan7476
#140 RDJeff
#141 rmpRmP
#142 oldfartpilot
#143 Big Lacy
#144 mnemennth
#145 Unclebuck21228
#146 WacoOne
#147 AV8RJIM
#148 retcaptafd
#149 dadragon
#150 boss_rc
#151 [email protected]
#152 msu68stang
#153 cowboy1969
#154 cubflyman
#155 akcub
#156 oldfartpilot
#157 jwrich
#158 rmyret
#159 tom_sandiego
#160 5skyhawk172
#161 archie05
#162 JerryM
#163 elaguilacalva
#164 arfwrecker
#165 I_Fly
#166 althepal88
#167 ROCKY1405
#168 scale buff
#169 Grumpy Monkey
#170 pt19 flyer
#171 Cloud Cruiser
#172 rye
#173 Props4ever
#174 oldfartpilot
#175 rcfighterjock
#176 cubkadet
#177 wildbills21
#178 RCJones
#179 FlyerInOKC
#180 WB6JGD
#181 Joey B
#182 cwhitacre21
#183 Yank II
#184 RCJones
#185 facia
#186 Aiden88
#187 spaceworm
#188 Sgt. Meyer
#189 LarsL
#190 jmcowart
#191 308jockey
#192 yak86
#193 p510851
#194 Bauer66
#195 baldguy
#196 acdii
#197 Mr-Punk
#198 skylark-flier
#199 braddock VC
#200 ThunderBoat42
#201 Ultimateflying
#202 FlyerInOKC
#203 John_M_
#204 Mako17
#205 bpoates25
#206 3136
#207 Loopdeeloop
#208 Jim Hargett
#209 deanz406
#210 darren4
#211 Murphey
#212 Horsepoweraviation
#213 Chucks
#214 Bob Howard
#215 Firewalkerd1
#216 Antares100
#217 motor12
#218 hogflyer
#219 bigbird3
#220 PeterC
#221 bwoofter
#222 Bush Flyer
#223 kevinf2501
#224 Jim Hargett
#225 shiprex
#226 Super08
#227 randomvector
Welcome new members
#3 acerc - Robert R
#4 Arup -
#5 Frequent Flyer -
#6 bikerbc -
#7 GAP RCU -
#8 rafeeki -
#11 CK1 – Chris
#12 Jaybird –
#13 heritageman -
#15 Saito18 –
#18 raydar –
#19 no1isnormal –
#20 JH313 –
#21 JNorton – John
#22 FJRrider –
#24 Edwin – Edwin
#25 Lavell – Lavell
#27 do335a –
#28 fred985
#29 Pa-18cub150 –
#30 cessna579 –
#31 cubcrasher –
#32 mac1va –
#33 morganflyboy –
#34 Steve Landron –
#35 mintie –
#36 Gordie M –
#37 extra-nut –
#38 snowball –
#39 eastkurt - Kurt
#40 JerryM –
#41 rcavi8or –
#42 meanrc –
#43 Rc Overkill –
#44 oldiron410 –
#45 Hill202 –
#47 SunDevilPilot –
#48 iflyj3 – Dan
#49 gluemaster –
#50 EddieC –
#51 CanDo – Les
#52 dabigboy – Matt
#54 woodworm –
#55 skipb
#56 mrdhub – Dan
#57 Homer712
#58 scaleman57 –
#60 psheffield
#61 quiltsfly
#62 G.Barber
#63 bobbailey
#64 scflyboy
#67 talob – Mike
#70 Glyder – Chuck
#71 smkrclfyer –
#72 jeffEE
#73 GW –
#74 lever02
#75 AB Bob – Bob
#76 rede2fly –
#77 Barn-E-Stormer
#78 Ray S. –Ray
#79 Daniel-EL
#81 jrb1 -
#82 on_your_six –
#83 BGCombs
#84 RevGQ
#85 jkr_1100
#86 Dope Fiend
#87 paero-RCU
#88 .50cal
#89 mrshea - Phil
#90 Cougar-RCU
#91 glenladen
#92 cublover
#93 lowbubba
#94 steve
#95 Gray Beard
#96 roaddog2
#97 biam
#98 rcpilotaviator
#99 funtana1
#100 rcavi8or
#101 GPutt33
#102 actionjackson
#103 sj3cub
#104 dreamwever
#105 phatbob02
#106 igoren
#107 N1EDM
#108 mrwad – Don
#109 dirtrod – Ty
#110 HawkI
#111 redkav
#113 SCOTT42
#114 5blue
#115 crazystick
#117 chevyman962000
#118 Mrj3cub
#119 Oldflyer2
#120 rogergh
#121 TEAMERICA
#122 cannonball200
#123 TripleDeucer
#126 VincentJ
#127 nalby
#128 fcf
#129 malitape
#130 sirzepp
#131 rmpRmP
#132 Rv7garage
#133 pt19 flyer
#134 JohnFH
#135 ahgoodman
#136 skyraider71
#137 Planejaw
#139 Stan7476
#140 RDJeff
#141 rmpRmP
#142 oldfartpilot
#143 Big Lacy
#144 mnemennth
#145 Unclebuck21228
#146 WacoOne
#147 AV8RJIM
#148 retcaptafd
#149 dadragon
#150 boss_rc
#152 msu68stang
#153 cowboy1969
#154 cubflyman
#155 akcub
#156 oldfartpilot
#157 jwrich
#158 rmyret
#159 tom_sandiego
#160 5skyhawk172
#161 archie05
#162 JerryM
#163 elaguilacalva
#164 arfwrecker
#165 I_Fly
#166 althepal88
#167 ROCKY1405
#168 scale buff
#169 Grumpy Monkey
#170 pt19 flyer
#171 Cloud Cruiser
#172 rye
#173 Props4ever
#174 oldfartpilot
#175 rcfighterjock
#176 cubkadet
#177 wildbills21
#178 RCJones
#179 FlyerInOKC
#180 WB6JGD
#181 Joey B
#182 cwhitacre21
#183 Yank II
#184 RCJones
#185 facia
#186 Aiden88
#187 spaceworm
#188 Sgt. Meyer
#189 LarsL
#190 jmcowart
#191 308jockey
#192 yak86
#193 p510851
#194 Bauer66
#195 baldguy
#196 acdii
#197 Mr-Punk
#198 skylark-flier
#199 braddock VC
#200 ThunderBoat42
#201 Ultimateflying
#202 FlyerInOKC
#203 John_M_
#204 Mako17
#205 bpoates25
#206 3136
#207 Loopdeeloop
#208 Jim Hargett
#209 deanz406
#210 darren4
#211 Murphey
#213 Chucks
#214 Bob Howard
#215 Firewalkerd1
#216 Antares100
#217 motor12
#218 hogflyer
#219 bigbird3
#220 PeterC
#221 bwoofter
#222 Bush Flyer
#223 kevinf2501
#224 Jim Hargett
#225 shiprex
#226 Super08
#227 randomvector
Welcome new members
