Cowl help, please?
My Feedback: (10)
I just hit a wall with my cowl. It's a Sig 1/5-scale Annivesary Cub, and I have a Saito 90TS for a powerplant. Imagine my shock and horror when, after painstakingly getting the drive washer hole perferct, and getting the side holes roughed-in to accomodate the opposed jugs... the engine just won't fit! [:@] It's like getting a too-big couch thru the front door!
I am wondering if maybe miniature piano hinges would work if I split the cowl, or if anyone has any suggestions for overcoming this. Thanks!
WA
<span style="font-family: Comic Sans MS">i'd split it and do the piano hinges, but how'd you get it marked and cut with out the engine fitting?</span>
MB, CANADA
You can split the cowl along its center line. Then, attach plywood tabs to one side, and drill for screw holes in the other side. The cowl can be fitted one side at a time and then fastened together.
In real planes, the cowls don't necessarily slide over the engines - they often hinge from the center line, or are removed completely.
Would it be possible to remove anything off the top opf the motor? On my single cylinder two stroke's when I haven't had enough room somtimes I have been able to remove the head and put it on after the cowal is on...Just a thought...
UltraSport BrotherHood #100 Cub Brother# 6 Biker BC
My Feedback: (10)
Thought about removing the valve covers, but 1) Did not want to risk getting any fiberglass dust in the valve train, and 2) The valve covers are not very tall in the first place. Looks like the piano hinge method is going to be my solution.... I guess
