 .91 4-stroke in a Senior Telemaster? >
Old 05-17-2012 | 03:47 PM
Leemata's Avatar
Default .91 4-stroke in a Senior Telemaster?
Would a Magnum .91 4-stroke fly the Senior Telemaster well? How about if floats were mounted? Any input is greatly appreciated.
Terry
Old 05-17-2012 | 05:18 PM
My Feedback: (60)
Default RE: .91 4-stroke in a Senior Telemaster?
I can't comment on the floats but I fly one that is powered by a Saito .82 and I generally float around at about 1/4 throttle. It is amazing how little power is required to fly the airplane. I think your .91 would be MORE than ample, even with floats.
Old 05-18-2012 | 08:35 AM
Leemata's Avatar
Thanks Chad, I think I'll go with it.
Terry
Old 05-18-2012 | 09:42 AM
My Feedback: (-1)
Mine had a very well used OS .60 or .61 and it would do a loop and roll. Had to dive to loop and the roll was pretty ugly but it would do it. A .91 four stroke would fly it great. As for floats?? I have never flown from water yet so?? I know on land a stout set of rubber bands could lift that plane off the ground.
Old 05-18-2012 | 09:04 PM
Red_Jeepster's Avatar
Four Stroke .91 works GREAT! I fly mine with an OS .91 Surpass and it is so well behaved. 1/2 or less throttle for cruising speed. There is plenty of power for getting out of trouble.
I haven't used floats, but in the winter on skiis it is fine.
My latest build is a highly modified Senior Telemaster with Magnum 1.20 4-stroke. Bomb bay is the entire center section - I moved the radio components to give me an empty box. It holds 80 ping-pong balls! (Or about 5 lbs of tootsi rolls)
Back to your Question - YES go withthe .91 !!!
Old 05-19-2012 | 04:16 PM
LargeScale88's Avatar
Got a saito 91 on my telemaster, 14x6 prop, will fly around at 1/8 throttle, and vertical forever.
Should be good to go!
Jason
Old 05-19-2012 | 08:24 PM
My Feedback: (13)
Hi Guys,
Built and flew one with a K&B .61...perfect match. No problem with floats with this engine...great model...great engine/plane combination too.
Soft Landings Always,
Bobby of Maui
