Goldberg Tiger Club
#426
My Feedback: (15)
RE: Goldberg Tiger Club
so that would give you the chance to set it up the way you like it. be careful with the fuel tank Height. if it is too high it could siphon and go rich all the time.
with four strokes the sweet spot it to get the middle of the tank in line or slightly lower than the height of the needle valve, or centerline of the carb.
#429
ORIGINAL: jkr_1100
Leroy Gardner #53
I think you will have a riot with a Tiger 60 with a DLE 20 on it. makes me want to build another.
I will post some build pics in a minute for you.
Leroy Gardner #53
DLE20 should be here in a couple more days, got it from www.valleyviewrc.com comes with mount, engine kill, switch and charge jack for $249 and free freight, nice little package I think. I can't do much without it as I need to see how much frontal changes I will do to accomodate it and larger fuel tank, also ignition and another battery.
I'm thinking 2 piece wing and joiner tube as done on larger sport and IMAC planes and expansion of vertical stab. for better knife edge control. Also like the idea of a removable upper cockpit and deck section to access servos and reciever and such. I'm going to have fun building this baby.
May not get started on the actual build till after Thanksgiving but will be gathering supplies in the mean time. Leroy PS, how do I get my number and signature to show, thanks
#430
My Feedback: (24)
CA
I also own a Tiger 2 40 size ARF with a Magnum XLS 46. It flies well with it, but I am wondering what your thoughts are on putting a Magnum 91 4 stroke. I read that one of you tore the firewall out of an ARF with a Saito 125, so I am wondering if it will be wise to put the Magnum 91 4 stroke. Your suggestions will be greatly appreciated.
ORIGINAL: Warbird40
I got a feeling that it has been done several times with no problem. It pay's to go through these two threads and see what others have done with their 40 size planes
Good luck with it and have fun.
Leroy
#432
"Hot dog", DLE20 just showed up, that kinda got the blood moving. Plans for Tiger are rolled up trying to straighten them out. Gota get the shop in order now, starting to itch a little. How many others have one of these to build or on the table. Would be more fun if 2 or3 of us were doing it togetherYeah!.
Tiger Club guy # 53
Leroy
Tiger Club guy # 53
Leroy
#433
My Feedback: (33)
I plan on starting mine on Black FridayI I finished up my Ace 4-40 with a Saito 56. You can see it on my models, I am doing a Tiger 60, thinking on a 120 4 stroke, Going to clip the wings, mod the elevator and rudder, Tail Dragger, that about it.
ED
ED
#434
My Feedback: (15)
ORIGINAL: Leroy Gardner
Well what's the hold up, they are going for $139 at Tower, I don't think that is out of line for this size plane. I just examined the kit a little more closely, wood quality is good and lazer cut parts just fall out. Dont think much of the hardware kit, looks like 40 size stuff so will up grade most of it and won't need any of the gear parts. I have most of the wood I'll need for the changes I have in mind. I read this whole thread twice as well as another plus some sport plane builds to use for direction I'm going with the Tiger.
ORIGINAL: jkr_1100
Leroy Gardner #53
Leroy Gardner #53
please be careful the section of the fuse
the fuse is know to be weak at the front and rear of the wing saddle. this is even more weak with the ARF. so if you remove the top of the fuse be sure to add back some structure to make up for this.
#435
My Feedback: (15)
ORIGINAL: Warbird40
I think you should do it right away. the amount of fun i have with the Saito 125 in the Tiger 2 ARF is tremendous.
Perhaps the .91 would be the perfect size to have tremendous power and light weight. to balance the 1.25 on the Tiger2 i added 1/2 oz of lead at the rear of the H. STab.
#436
My Feedback: (15)
ORIGINAL: nh4clo4
ED
ED
I don't know if Leroy can wait. I do hope to see lots of pictures. I regret not taking more pictures step by step.
#437
ORIGINAL: jkr_1100
ORIGINAL: nh4clo4
ED
ED
"Boy you are right about weeknesses in the body", I saw that right off when I seen the plans, then I seen the actual fuse. pannels. I have a 12'X60" 1/8" ply pannel already so we'll take care of that right off. Any way there are going to be some other changes in the fuse. I want to invert the engine and raise it up for more ground clearance for prop. I'll post what I'm doing as soon as I start doing it, may intrest some others thinking of useing the DLE20.
When is black friday, day after Thanksgiving is'nt it ? I will be working on the plans, my changes will be in red and I hope they will show well so you all can see what I'm doing. I also am going with outboard ailerons so will have wing work to do also. I said this was going to be a bashed fun build for me but it will not change the profile much at all.
Stay tuned, more to come Leroy # 53
#438
Hey jkr #1, mind if I call you that. Do you or doI do some that puts our name and # on our posts ?
''Boy you are right about weeknesses in the body'', I saw that right off when I seen the plans, then I seen the actual fuse. pannels. I have a 12'X60'' 1/8'' ply pannel already so we'll take care of that right off. Any way there are going to be some other changes in the fuse. I want to invert the engine and raise it up for more ground clearance for prop. I'll post what I'm doing as soon as I start doing it, may intrest some others thinking of useing the DLE20.
ORIGINAL: jkr_1100
ORIGINAL: nh4clo4
ED
ED
#440
ORIGINAL: thailazer
Leroy.. What size prop will you put on the DLE20? Ground clearance might be a problem, but with that power you won't be spending much time on the runway! Any snow in the hills above CDA yet?
ORIGINAL: jkr_1100
ORIGINAL: nh4clo4
ED
ED
Well you know where to find me, later, Leroy Tiger #53
#441
My Feedback: (15)
ok to set your signature line (Tiger club #53) click on "my account" at the very top of your screen" then click on "forum settings" and fill out your signature there.
#442
Thank you jkr_1100
Question for experienced builders only:
The strip ailerons on the Tiger 60 have approx. total of 45 sq. in. area, I'm moving them out board and the figured new size would be 3" wide and 15" long to have the same area as the strip. QUESTION, can the width be reduced and how much, I do not want to alter the performance in what I'm doing. I do not know what the difference of air flow is across the whole wing half verses the outer 17 inches and am I going about it in the right way. I know some of you have done this.
Don't worry about the required work involved, I can handle it with no problem. Thank you.
#443
Thank you jkr_1100
The strip ailerons on the Tiger 60 have approx. total of 45 sq. in. area, I'm moving them out board and the figured new size would be 3'' wide and 15'' long to have the same area as the strip. QUESTION, can the width be reduced and how much, I do not want to alter the performance in what I'm doing. I do not know what the difference of air flow is across the whole wing half verses the outer 17 inches and am I going about it in the right way. I know some of you have done this.
Thank you jkr_1100
#444
Hi Toivo, will be good to have you here, judging from what I found you are a very experienced RC man. Thanks for the assurance in what I'm doing, avionics is not one of my strong points. I run on logic and commen sence but that does'nt always work in some cases. Are you building this Tiger also or just along for the ride, I hope this thread gets active pretty soon, should be fun.
#445
Leroy... Your Tiger with the DLE20 will be an interesting build so I hope you can upload some photos. If you go back a few pages on this thread you can see my Tiger 2 with a 35AX. Haven't flown it for about six months as the runway is not good enough here for it yet. Hoping to get it ship shape by the new year. Here's a video I did for some friends in Scandinavia that were flying off ice two years ago. Just had to rub it in!
[youtube]http://www.youtube.com/watch?v=oEa2ZoGoyUQ&list=UUrZ55tPOXT60Xwkqe53ZSwA&index=2&feature=plcp[/youtube]
#446
This is such a great hobby. We all over the world love it and help one another out through rcu! I have met folks from all over at flyins. I have enjoyed that about the hobby the most and have many new freinds because of it. The Tiger I am building now is getting retracts I will post pictures as I can.
#447
ORIGINAL: thailazer
"Ok, I think ya got us beat on the snow, nothing like living in a igloo come winter".
I'll be doing posting on the build and I'll try to keep it intresting Toivo.
reguards,
#448
My Feedback: (10)
hi guys
does anyone have plans on there pc or a pdf file that they can e-mail me for the goldberg 60 size tiger ,copy maxs said that my plans are not good enough to run though there copyer ,thanks rye e-mail [email protected]
#449
My Feedback: (15)
ORIGINAL: rye
hi guys
hi guys
this would require a special large format scanner right?
#450
Those plans have copyright protection and no one will copy them, at least their not suppose to. I tried that once at Kinkos and they said they could'nt do it for stated reason.
