~~Sig Kadet Brotherhood~~.
#1326
How much 'slop' are you talking about? More than 10% of the flaperon chord when measured at the trailing edge? I had similar worries about the friese ailerons and flaps on my Seniorita, but then I measured the acceptable 'slop' limits on my bigs and scales those numbers down. I was well withing tolerance, provided my ailerons are balanced correctly. That's where it took me three tries to build a decent set of ailerons and flaps to match. Weight distribution is a little bit harder to figure out when your chord is only
1 1/4 inch.
1 1/4 inch.
Would you have any thoughts/experience with these style flaperons?
#1329
Very nice and stylish horn! And, no. I don't really have any experience with this kind of flaperon on a model. How ever, I did rebuild a big many years ago, Avid Flyer serial number 2, that had Junkers flaperons. I remember something strange about the control system and the way the flaperons were connected. It may have been for a similar reason. I'll see what I can pull out of my dusty memory and google.
#1330
#1331
I think i see your reasoning but I want to keep the linkage connected directly over the hinge point to keep the forces in play here to a minimum. My thought is that the control horn is most effective mounted where it is at.
#1332
Decided on the colors and design for the fuse, still mulling on the design for the tail feathers and the larger canvas of the wing.
You can see the "bump" where I had to enlarge, raise the height of the firewall so the engine mounts fit when I turned the engine to get the muffler out the bottom. I think it actually adds a little character to the front.
#1333
Big Tee,
The 'something unusual' I was remembering was for the folding wings on the Avid. The flaperons are driven by a torque tube that extends into the fuselage, attached to a pushrod that has a strange adjustable universal joint on the end. Had nothing to do with balance or flutter control. Have you considered tension springs to help pull the flaperons up and dampen the 'slop'?
#1336
Big Tee,
I agree on the bump.....I was concerned at first for the "look" but I kind of like the effect. I was thinking Cessna as well, I used to fly a 182 but I think your more right with the 206.
#1337
#1338
I just let my wife do my schemes. I will then make minor changes. She understands what I need for visibility. I will throw out ideals and then she just makes it all work. The plane in my avatar is mostly her scheme design.
She will come up with colors and shapes and then we work together to to get it down to fine detail, size of patterns etc.
Ken
Ken
#1341
Ken
#1345
Unless the grand daughters want me to build a model for them, I seriously doubt that there will be a purple and pibnk airframe produced in my shop.
The little T-craft was painted using Ace aerosol cans. The colors are Navajo White and Terra Cotta. My wife hit the mark on this one, and I will probably re-visit the combination on future airframes.
I think my Kadet Sport would look great, done that way, when it come time to re-cover it.
#1348
Jim
Yes, It's a kit, from Alien Aircraft. It has their complete electric package. http://www.alienaircraft.com/k502.htm
I hope to perform the maiden tomorrow.
If you get one, keep an eye on balance. Mine built tail heavy.
Mike, I've had two Ace Clipped wings. Both were white. One had blue trim, the other green.
Sig has one, now. It could easily find it's way into my fleet.
#1350
My Feedback: (98)
BigTee
Black in Vegas? To quote a famous author "Bubble bubble toil and trouble. "
On driving the ailerons, have you thought about driving them from the LE, with a push-rod going vertical to the servo-arm? Not much possibility for slop in that set-up.
