Too much glue applied
BSI's Un-Cure debonder works like acetone but has a much slower evaporation rate. As has been said, CA is much easier to remove within the first 15 minutes of curing. Even though we make the stuff, I have to agree with Zor that it is usually faster just to use a razor saw to separate two parts. We use the Un-Cure to clean up all our bottling equipment, but personally I only use it to get my fingers unstuck (where the nozzle on the bottle works as a great wedge to force the skin apart as the debonder softens the CA) and to remove CA from non-porous surfaces, such as ceramic objects after I repair them.
