~~SIG Brotherhood ~~
#3376
The instruction booklet has a half-windshield graphic on page 35. Check my site, https://wanderings-ds.jimdo.com/sig-rc-kits-41-60/ , kit RC48. Just download, print the page and go for it.
CORRECTION: All 3 of the last 3 pages - the entire windshield is there.
Thanks again
Gerry
#3377
FINALLY!!!!! At long last, I found the f.t.p. program that allows me to simply digitally transfer those instruction manuals that are too large to put in the website - and, sadly, I've actually had it on my computer for nearly 4 years and didn't remember that I had put it there.
dropbox.com works just great!!!!!! No more zip-drives, no more snail-mail!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!
#3379
Hello again to anyone that help me. I have missed place the windshield pattern to my Sig 1/4 scale J3 Cub that's on my plans. The plans have been cut up, so the section that has the windshield pattern on it is missing. If anyone has that section of the plans, I would be happy to pay for it, if you can mail it to me. I never throw any of my plans away until the plane is crashed and gone, but still it's missing. If anyone can help me, please let me know.
Thanks again. Gerry
Thanks again. Gerry
The blasted site refused to recognize my password. The reset failed. Appears to be sorted out now.
Anyway, on the full size plane, in flight, the window is held open by the wind. Since you always fly the plane with a positive angle of attack - not incidence - the wind will always hold it open.
Not being satisfied with that and wanting it to be held open while parked on the ground, I devised a simple method.
There was a spring loaded, rotating "L" shaped wire which protruded from the bottom of the wing. It came out right next to the edge of the window frame. To engage, simply pull down - about 1/4 inch - and rotate to catch the window frame. Worked perfectly.
Also, you and everyone else should be advised that all the Sig kit manuals are available on their website for free download. Just look for the model you are interested in and you will find the link on the description page. The windshield template is in the manual.
Very easy and no fiddling around with dropbox, google accounts or any of that stuff.
All the best with your build. You will finish with a great flying Cub.
#3380
Yes, true - that works for almost any plane PRESENTLY ACTIVE on the SIG website. However, for those discontinued planes (75% of the history of what SIG has produced) the only source that I know of is what's in my site. For the ones too big for my site, my only option at present is to link through dropbox - which seems to be working just fine. At least the info/data/files is/are still available somewhere.
Who knows? Maybe, one day in the future, SIG will re-instate their "plans" pages, like they had in the old website. But until that day...
#3381
From what I gather talking to the new owner, Herb, that is not the direction they will be going. After the fiasco of the Rascal, they won't be spending anymore time on kit R&D, and once out of production, that's it, done. Rumor has it they lost a bunch of hard copy plans for older kits in a fire, but not sure where I heard or if true. When Mike was alive, I asked if they will be producing the Liberty Sport any time soon and his answer was flat out no. Anything new from SIG will be ARF and not kits, and as each kit sales dwindle, they too will go away. Sad state for the hobby.
#3383
Hello guys it's Gerry the Wetbird again. I had to put my build on hold for a bit because its boating season so I have a lot to do with getting all that ready. But I also found a Thread in(Piper Cub J3 1/4 - SIG or BUSA) by John_M_ 02-21-2014. The thread is pertaining to adding a door & window as an afterthought. That would be me, and the door & window has already been installed. After searching the web for articles about reinforcing the door cut out the way it shows in the plans. Of course the plans doesn't show anything about adding the door & window to your build, it would have to be planed in advance before building or as an afterthought. I did some reinforcing but not sure if what I did would add strength to the structure. I don't want the wing coming off at takeoff or at anytime for that matter.
My question is: Has anyone done the reinforcement like what's in the article/website below. I haven't worked on my cub for a bit, but getting ready to start again, first have to reinforce the area where I cut the door out. Looks like I'll be using 5/32 piano wire along the top of the window and down along the side of the cabin brace.
John M wrote the thread below. I'm glad I found it, I was hoping to hear from him. Let me know what you think! ……………………………………………………………………………….
The Sig kit wasn't upgraded... the door / window mod you have seen on other sig 1/4 scale cubs was done by the builder... the door frame has to be re-enforced, preferably during the build... I'm in the process of cutting out the door on a already built 15 year old cub... its a bit more tedious doing the door after the fuselage has been built, but not impossible... I'll be posting some images on the ***Cub Brotherhood*** thread when I finish prepping all the bits an pieces... right now I have the right side fuse almost ready to glue in the re-enforcement wire, then I will move on to the left side fuse and re-enforce that side... then I'll be able to go back and cut out the door and window on the right side and then remove the 2 formers that the re-enforcement wires replace... then the cockpit will be free of any obstructions and can be fitted out with the interior.
Go to this link... Cub Man has posted instructions on how to do the door / window mod on the sig cub
http://thecubden.org/j3l4-related/op...oor-and-window
#3384
If you want to get away fron the "instant gratification", take away all of the things that make that possible. I personally like the fact that some school districts are taking away smart phones when a student gets caught using it in class. To get them back, the student has to pay what amounts to an "impound fee". To me, that's the perfect place to start. The second place would be to require students to take a class that REQUIRES THEM TO HAVE TO MAKE OR REPAIR SOMETHING. This could be like the tried and true woodshop, auto shop, home economics, etc.
#3385
This should probably go to the "Where have all the builders gone?" forum but, what the hey.
It's the modern culture we now live in.
Kids are being taught by their parents and their schools that a college education is mandatory and trade school is for poor people. With that mindset embedded in kids' brains, it's no wonder they don't want, or feel they should have to, work for anything, let alone create anything, like a model airplane.
Carpenters, plumbers, electricians, and such is what this country needs, not computer programmers, lawyers, and financial advisors.
Okay, I'm done with my little rant.
By the way, acdii,what's the deal with Sig's Rascal "fiasco?"
#3386
#3387
I see.
I've built two of the 48' Rascals. I consider them to be the ultimate park flyer. But when they're blown up to these grotesque monsters, the Q-T factor is eliminated. I don't know who green-lit these behemoths, or why, but I'm afraid Sig is losing their way.
Although, I do love my 48" Rascal, it's a rather peculiar build. For example, the wing uses no trailing edge stock. Weird.
But, she is a sweet ride! And such a pretty thing.
Cheers!
Cheers!
#3388
I have a Rascal C and love the heck out of it. I think what happened was SIG saw Balsa USA and others blowing up their designs and jumped on the bandwagon without having the technical know how to pull it off. Going to an outdated all ARF mentality is going to kill them. I know several LHS that only order from SIG when they need a kit and add on other items they have a demand for to the order. Kill the kits nd suddenly there is no reason to do business with them.
#3389
I have a Rascal C and love the heck out of it. I think what happened was SIG saw Balsa USA and others blowing up their designs and jumped on the bandwagon without having the technical know how to pull it off. Going to an outdated all ARF mentality is going to kill them. I know several LHS that only order from SIG when they need a kit and add on other items they have a demand for to the order. Kill the kits and suddenly there is no reason to do business with them.
So, how do we get them to see the light?
#3391
And that, as they say, is that. These companies are moving so quick to jump on the ARF bandwagon that they are totally forgetting the rest of the people that have kept them in business for so many years. Maybe someone needs to remind them of that little fact. Since it doesn't pay to do "one off" runs, to me it makes sense to run something like 10 kits just so they have a few in stock. Otherwise, they won't be in business for too many more years
#3392
Banned
The problem I see is kids are instilled with the idea that they're too good to perform many routine tasks. How many actually change a tire these days? Or do they wait for Daddy to call the auto club? Or wash dishes the old fashioned way? Heck, spending 3 minutes to load a dishwasher is too much for most of them.
McDonalds use to be the entry level job for teenagers. Now it's a career, demanding a so called living wage for the uneducated, middle aged and elderly who thought social security would do it for them. So now the teenagers sit in their parents basements, drinking or smoking dope and playing with their latest game console. And society pays for it!
Kids are no longer taught the basics of living. The nasty, daily, boring things necessary to make it from one day to the next. And the fault lies with the so called adults.
There are exceptions. Don't get me wrong. A good friend of mine is a retired Marine. And he raised his kid with the discipline one would expect of a Marine. His oldest just started his Freshman year at M.I.T. Wonder if there's a connection there?
#3394
I remember being taught by example when I was a kid. "This is work get use to it, you'll be doing it your whole adult life." If I wanted something I went out and found some type of work to earn a little money. The folks didn't buy it for me everything. When I got my first car it was when you got your money saved I'll help you go look. I did the same with my boys too. When they wanted a cell phone and a car they went out and got a parttime job after school. Now one is a Project Manager for a software company, one is a Paramedic, one runs a grain elevator and studies for the ministry, and the last one is a Disabled Army Veteran that stills works. He is a gate guard for a gated community and is a Reserve Sheriff's Deputy. He'll never be able to be a full fledge deputy but he can ride shotgun and be back up to the fulltime deputy. They are all married two own their own homes and two are looking into it.
#3396
Don't totally agree. I think the country needs all of those and then some. With Lawyers and Politicians being relegated to their proper place at the target end of the gun range.
#3397
I am all for it, in fact I am subtly driving my son towards a stint in the Air Force so he can pursue what he feels he wants to do, aerospace engineering. My daughter though, that would be a tough one, she's a natural artist who wants to do interior design.
Another benefit of forced military service is it would weed out the gangs, and crime would drop dramatically.
#3398
DAMN!!!!!!!!!!!!!!!! I hadn't thought of that, but you're probably right. It's hard to operate a gang in the military but, on the other hand, those that really want to be in a gang afterward would have combat training so it could be more bloody than it already is.
#3399
Banned
I'm going to chime in here as well. You all seem to be saying the same thing, just in different ways. As I see it, we really need to follow Israel's example. Everyone coming out of high school should be required to spend a three to four year tour in the military to deprogram them from their thinking that they're "entitled". ..................
Up until a couple of years ago I was heavily involved as a government contractor with the DoD. Prior to that I was myself Air Force for 20 years. I've been in and around the military for 43 years total. And they are not what they were 43 years ago.
Our military today is little more than a giant social experiment being conducted by the left. Did you know the military will pay for sex change operations and treatment among active duty members today? I am amazed that they still manage to get the real job done. Then there's the problem of fully 1/3 of American youth being too fat for military service.
I could go on but looking at our military today, had it been this way 45 years ago, I never would have joined.
#3400
Banned
Makes it tougher for the police when the bad guys are as good or even better at urban combat. Of course, when the police are afraid to shoot for fear of starting a riot, that doesn't help either.
