source for ailerons >
source for ailerons
source for ailerons
Old 02-08-2014 | 06:08 PM
My Feedback: (25)
Default source for ailerons
does anyone know of a source for precut and tapered ailerons; 1-1/8" cord is perfect? I just got my hands on a 95% complete GP Patriot that is missing the ailerons.
Old 02-08-2014 | 06:35 PM
One I've found is Specialized Balsa.
Old 02-08-2014 | 09:52 PM
If you've got a good local hobby store, they may have what you need. A good hobby store has a cabinet full of assorted shapes and sizes of balsa, hardwood, and light ply for model building.
Old 02-09-2014 | 06:31 AM
Sig doesn't show anything 1 and1/8 on the websight.
http://www.sigmfg.com/cgi-bin/dpsmar...ntF.html?E+Sig
If nothing in the link looks right I would call them. A Sig airplane I had sitting around for a long time had warped ailerons. I called them,and they fixed me right up. They have a lot more stuff than they show on their websight.
Old 02-09-2014 | 06:40 AM
OldScaleGuy's Avatar
Balsa USA has a decent variety. They have 1 1/4, easy enough to trim. http://shop.balsausa.com/product_p/225.htm
Old 02-10-2014 | 04:24 AM
TomCrump's Avatar
Most local hobby shops carry tapered aileron stock, If you can't find the perfect thickness, buy large, and sand to shape.
Old 02-10-2014 | 08:58 AM
Ailerons are pretty easy to make. You can tilt a bandsaw table a bit and rough cut out the stock then finish shaping the LE with sandpaper or you can shape then with a handplane if you have one. I've also made them with nothing more than a long sanding "T" bar. You'll have them done in much less time than it will take to find someone who carries that size.
Carl
