Reload this Page >
Balsa USA Stingray 120
Old 03-22-2014, 09:42 PM
bicyclemonkey
My Feedback: (7)
bicyclemonkey's Avatar
So, longerons (I think is what the manual called them) are now on the fuselage halves.
and the firewall.
ID:	1982270   Click image for larger version
Old 03-23-2014, 03:23 PM
bicyclemonkey
My Feedback: (7)
The fuselage is starting to come together, finally!!!
ID:	1982272   Click image for larger version
Old 03-24-2014, 11:34 AM
Gray Beard
My Feedback: (-1)
Very impressed with this build. Hard for me to think this is your first, it's that good. Good choice on your servo selection too. This is a plane I have never built but at one point in time there were a lot of them flying. Fantastic plane for people wanting to get into giant scale flying.
Old 03-24-2014, 12:53 PM
bicyclemonkey
My Feedback: (7)
Thanks for the awesome comment! It's been fun but I was a little intimidated to start with a BUSA kit but I'm glad I did and it's much easier than I expected. I've really enjoyed adding things not in the manual.
I think for now, I'm going to throw the electric motor on here just for the ease of setup. If it survives the maiden and looks to be a plane i won't get bored with after a half dozen flights, I may throw a four stroke on it.
ID:	1982274   Click image for larger version
ID:	1982275   Click image for larger version
Old 03-24-2014, 01:01 PM
bicyclemonkey
My Feedback: (7)
EMPTY!!!!
I never thought emptying a bottle of old wood glue wood feel so satisfying.
Old 03-25-2014, 06:39 PM
  #31
bicyclemonkey
My Feedback: (7)
It's starting to resemble a fuselage!
ID:	1981623   Click image for larger version
Old 03-26-2014, 09:05 AM
  #32
starbird2000
My Feedback: (14)
So how are you loading pictures of you're build? I do not have any problem seeing pictures on other threads, but on this thread, I can't see any of the pictures....Bummer....
Old 03-26-2014, 11:39 AM
  #33
bicyclemonkey
My Feedback: (7)
I have been linking the images from my imgur account. It's been showing up for me every time on three different computers...hmmm.
Old 03-26-2014, 12:29 PM
  #34
bicyclemonkey
My Feedback: (7)
Finally getting to use some of the fixtures for my magnetic building board to glue cross braces.
ID:	1982279   Click image for larger version
ID:	1982280   Click image for larger version
Old 03-27-2014, 03:04 AM
  #35
starbird2000
My Feedback: (14)
I can view the picture with the fuse sitting on the table with the bowl of fruit in the backround, but so far that is the only one that is visible to me. I'm hoping the others will show up sometime soon...
Old 03-27-2014, 07:03 AM
  #36
bicyclemonkey
My Feedback: (7)
Can you see this pic ok?
ID:	1981933   Click image for larger version
ID:	1981934   Click image for larger version
ID:	1981935   Click image for larger version
Old 03-28-2014, 08:56 AM
  #37
bicyclemonkey
My Feedback: (7)
Check and see if you can see all the other pics now. I used the insert image button this time. All the images should now be thumbnails you can click on to make larger.
Old 03-28-2014, 08:59 AM
  #38
bicyclemonkey
My Feedback: (7)
I've been waiting on a couple drill bits to arrive in the mail so I can drill out the wing dowels.
In the mean time I started on the tail.
Those magnets are AWESOME!!!
More whittling to do.
ID:	1982282   Click image for larger version
ID:	1982283   Click image for larger version
ID:	1982284   Click image for larger version
Old 03-29-2014, 07:22 PM
  #39
bicyclemonkey
My Feedback: (7)
Got the wing dowel holes drilled!
ID:	1982611   Click image for larger version
Old 03-29-2014, 07:29 PM
  #40
bicyclemonkey
My Feedback: (7)
Wing dowels in place.
Drilled the rear wing bolt blocks.
I tapped them for the nylon wing bolts then hardened with thin CA.
ID:	1982613   Click image for larger version
ID:	1982615   Click image for larger version
ID:	1982616   Click image for larger version
ID:	1982619   Click image for larger version
Old 04-01-2014, 08:23 AM
  #41
starbird2000
My Feedback: (14)
I do not know what you did, but I can see the pictures now.... Thanks you. I have this kit wanted to see how it went together...great build thread!
Regards
SB
Old 04-01-2014, 09:54 AM
  #42
bicyclemonkey
My Feedback: (7)
Thanks, glad you can see the pics!
Back to the tail. I have to cut down this piece for the center section of the horizontal stab.
I found a piece of somewhat see through paper from my recycle bin.
Trimmed it up a little and used spray adhesive to stick to the balsa.
Ran it through the scroll saw.
done.
ID:	1983229   Click image for larger version
ID:	1983230   Click image for larger version
ID:	1983231   Click image for larger version
ID:	1983232   Click image for larger version
ID:	1983233   Click image for larger version
Old 04-03-2014, 09:32 AM
  #43
bicyclemonkey
My Feedback: (7)
Finally finished framing the H-stab. (and added some extra lights in the garage).
I think I'll go ahead and build the elevator joiner like the plans call for.
ID:	1983683   Click image for larger version
ID:	1983684   Click image for larger version
Old 04-04-2014, 08:10 AM
  #44
bicyclemonkey
My Feedback: (7)
Got the epoxy applied. For the dowel rod, wrapped a round pencil, which was a bit smaller diameter than the dowel, in sanding paper and it sanded a perfect size curve.
Here it is without all the magnets in the way.
ID:	1984010   Click image for larger version
ID:	1984011   Click image for larger version
ID:	1984012   Click image for larger version
ID:	1984013   Click image for larger version
ID:	1984014   Click image for larger version
Old 04-04-2014, 07:41 PM
  #45
JRgraham
Looking good man
btw; I was able to see the pictures before. It may have been some sort of anti-virus or adware of some kind blocking the images before.
Old 04-04-2014, 07:53 PM
  #46
bicyclemonkey
My Feedback: (7)
Originally Posted by JRgraham
Looking good man
I could see them on all my PC's, both at home and my office. This way they take up less space I guess and they can be clicked on to view larger.
The v-stab went together faster than I was expecting.
Old 04-04-2014, 09:18 PM
  #47
bicyclemonkey
My Feedback: (7)
Started on the turtle deck. The instructions called for gluing this like so:
It seemed it would break off easy just being connected on each of those 1/4" balsa sticks so I added a wider balsa block underneath.
ID:	1984158   Click image for larger version
Old 04-07-2014, 07:17 PM
  #48
bicyclemonkey
My Feedback: (7)
This is just a sport plane, not much more than an advanced trainer. If this is how Balsa USA designed it, it'll probably be just fine. Then again, like with the dowel rod, it's kinda twisty.
Old build threads here on RCU stated that the first former of the turtle deck is a weak spot and needs bracing if you use a 1.20 or larger engine. Since I'm not 100% sure of the power source I added extra material.
ID:	1985202   Click image for larger version
ID:	1985203   Click image for larger version
ID:	1985204   Click image for larger version
ID:	1985205   Click image for larger version
Old 04-10-2014, 07:28 PM
  #49
bicyclemonkey
My Feedback: (7)
Got the landing gear block in place for the upgraded landing gear I'm going to use. This will look much better than the bent wire gear the kit came with.
I cut 1/4" ply to shape with my scroll saw.
Good fit.
I added some square stock for added strength.
ID:	1985877   Click image for larger version
ID:	1985878   Click image for larger version
ID:	1985879   Click image for larger version
Old 04-12-2014, 06:01 PM
  #50
balsa brain
Where did you get the landing gear from?
