Balsa USA Brotherhood
#2101
My Feedback: (17)
I have not used Oratex but I have read on other sites that it is very much like Solartex. Read the instructions and I think if you go on You Tube and search Oratex & Solartex, you will find several videos on the subject. Try a small piece on some ope frame work and sheet balsa. Let us know what you think. Post pictures if you can.
Rich
Rich
#2107
Dont mind the bench, I was sorting some boxed up stuffs... boy what a project that was, anyways its covering time after I take the tail back off and get the landing gear off so I can get the fuse covered. Oh the tail on this monster is bolted on so If I need to remove it I can.
#2113
Pictured above , are some turnbuckles that I made, 14 to be exact , they were time consuming but easy with a small collet lathe and a bridgeport to drill cross holes and slot the clevis ends.
#2114
Camel Question. I've had a couple of side projects but I'm finally getting back to finishing up my 1/4 scale Camel. I finally got tired of fighting with the Homelite conversion.The Homelite on my Nieuport 17 still runs like a top after 14 years but the engine on the Camel just wasn't working out. I think there is a compression issue. I may move my conversion parts to a different core. In the meantime I finally just ponied up and bought a new G-26. It is a nifty little engine and it seem to be the engine pictured in the BUSA Camel's manual. The G-26 is considerably lighter in weight so i am having to rebalance the airplane. This leads to my question. For those who are flying the Camel, where do you end up balancing it? The plans appear to show a balance point four inches back from the leading edge of the upper wing. This is at 29% of the upper wing chord but doesn't seem to take into account the lower wing. If you figure the mean aerodynamic chord it looks as though the balance point should be over 1.5 inches farther aft. I need to double check all my figures and I don't want to try to take off with a tail heavy Camel. I'd like to hear what others are using as a balance point.
#2119
My Feedback: (17)
Skyrydr2, Keith, it is nice to welcome a new brother into the Balsa USA Brotherhood. We are a group of RC flyers/builders are proud to fly their airplanes. Please add your Balsa USA Brotherhood number to the your RCU Signature.
Again Welcome. Keith. Keep the updates and pictures of your build coming. We all are looking forward to the maiden flight.
It would be helpful for me if all BUSA Brothers would post their BUSA Brotherhood number in their signature. If I have missed anyone please let me know.
Balsa USA Brothers
#1 jwrich, (Rich), Enid, OK, USA
#2 Jeffo New Baltimore, MI, USA
#3 ARUP KY USA
#4 RCKen Lawton, OK, USA (RCU Forum Manager/Admin)
#5 mattnew, Haverhill, MA, USA
#6 surmovik60 VA USA
#7 GerKonig, Levittown, PA, USA
#8 Granpooba, Queensbury, NY, USA
#9 radfordc (Charlie), Lansing, KS, USA
#10 balsa brain, Jacksonville, FL, USA
#11 3136 Victoria Austrialia **
#12 wwoneguy, Beltsville, MD, USA
#13 vertical grimmace, Ft. Collins, CO, USA
#14 rcmiket, El Paso, TX, USA
#15 bpoates25, Riverview, FL, USA
#16 PiperDriver, Rolling Meadows, IL, USA
#17 68goat Alabaster, AL, USA
#18 jlsimon, Long Valley, NJ, USA
#19 pat s, Candor, NC, USA
#20 pending IN USA
#21 Steve Percifield, Noblesville, IN, USA (Sir Percy)
#22 opol, Two Harbors, MN, USA
#23 Zero, Houston, TX, USA
#24 tonyos, Madison Heights, VA, USA
#25 b206, Opdyke, IL, USA
#26 LonnieMcc, Carriere, MS, USA
#27 eindecer3, McMinnville, TN, USA
#28 flyer35, Ilion, NY, USA
#29 jeffEE, Farnington, NM, USA
#30 s3nfo, San Diego, CA, USA
#31 Kwikfli, Winfield, KS, USA
#32 JDHammer, Slippery Rock, PA, USA
#33 Ikruse, Lawton, OK, USA
#34 bobbailey, Chesapeake, VA, USA
#35 Vampire, Bath, PA, USA
#36 zemkes_wolfpack, Winamac, IN, USA
#37 triumphman49, Decatur, AL, USA
#38 SRQFlyer, Sarasota, FL, USA
#39 Daniel-EL, Maumee, OH, USA
#40 hairy46, Sinclair, WY' USA
#41 pettit, Durham, NC, USA
#42 Hrannar, Patrekfjordur, Iceland **
#43 lowbubba, Miamisburg, OH, USA
#45 FokkerD7, Cable, OH, USA
#44 FireBee, Chesapeake, VA, USA
#46 iampilot2, Middletown, OH, USA
#47 Wagon1,Penscola, FL, USA
#48 darren 4, Eau Claire, WI, USA
#49 Luxuswaffe, Hialeah, FL, USA
#50 dryverman, West Rutland, VT, USA
#51 otterrc FL USA
#52 cooper998, Newark, DE, USA
#53 lazyace, Buffalo, NY, USA
#54 wings2an3 Monroe, NY, USA
#55 The Pamster, Dallas, TX, USA
#56 lucasar15, Pottsville, PA, USA
#57 AMA74894, Spicer, MN, USA (Moderator Jim Buzzeo)
#58 squidman, Waco, TX, USA
#59 M_Callahan, South Lebanon, OH, USA
#60 Karp050555, Philadelphia, PA, USA
#61 optech, San Diego, CA, USA
#62 ashby NSW Australia **
#63 R/C Art, Shelbyville, IN, USA
#64 on_your_six MD USA
#65 Highflyer2, Alpharetta, GA, USA
#66 dddaviddean NJ USA
#67 Quagmire, Costa Mesa, CA, USA
#68 pending CA USA
#69 ratshooter, Burleson, TX, USA
#70 TXAG96, Augusta, MI, USA
#71 R/C Ray, Valley Cottage, NY, USA
#72 feep, Pelham, NH, USA
#73 sdcranford, Willard, MO, USA
#74 buzzard bait, Ithaca, NY, USA
#75 chadasmus, Freedom WI, USA, (BUSA Team Pilot, Builder and Designer)
#76 fokv25, Westfield, IN, USA
#77 Dynamic, Stratford, WI, USA
#78 WinterHawke, Waukesha, WI, USA
#79 t6racer NSW Australia **
#80 NM2K, Ringgold, GA, USA
#81 rcjunky67, Belleview, FL, USA
#82 AndyF Ft. Wayne, IN, USA
#83 freefall2907, Ottumwa, IA, USA
#84 a65l, Virginia Beach, VA, USA
#85 Grimracer, Urbana, IL, USA
#86 Corsair2013, Granytsville, UT, USA
#87 Chevelle NY USA
#88 eagledancer, Orlando, FL, USA
#89 Leroy Gardner ID USA
#90 ANZAC Australia **
#91 Spadsriver09, Southbend, IN, USA
#92 PSB, Malven, OH, USA
#93 bradpaul, Apopka, FL, USA
#94 MRadu, Los Gatos, CA, USA
#95 HorsePowerAviation, Cincinnati, OH, USA
#96 Shoestring, Granite, MN, USA
#97 David Gladwin, CookhamBerkshire, United Kingdom **
#98 Rich6170, Springfield, OH, USA
#99 Wildbills21, Menominee, MI, USA, (Team BUSA, pilot, builder,& chief mechanic)
#100 Rickj, Akron, OH, USA
#101 Geezeraviation (Doc), Houston, TX, USA
#102 Flyboy077, Uniontown, OH, USA
#103 Shelstrm. The other Doc), Lancaster, WI, USA
#104 Drude, North Port, FL, USA
#105 bschatz, West Hills, CA, USA
#106 RCDuffer, Valley Center, CA, USA
#107 capnpaul, Orillia, ON, Canada **
#108 p38nut, Indianapolis, IN, USA
#109 yoda64, Bloxon, VA, USA
#110 Jaybird, Hallowell, ME, USA
#111 mbnt, IL, USA
#112 Foodstick (Lance), Ankeny, IA, USA
#113 adec, Perthaustralra, Australia **
#114 Navy, Orange Park, FL, USA
#115 RD Jeff, Anchorage, AK, USA
#116 Mistral 12, Granbury, TX, USA
117 JKEpps, Greenbelt, MD, USA
#118 FlyerInOKC, Okla, City, OK, USA
#119 PT19, Buna, TX, USA
#120 Jim Scott, ?
#121 Srecker, Erie, PA, USA
#122 bigbird3, Williamstown, VT, USA
#123 Monsour, Fisherville, KY, USA
#124 Marksp (Mark), Redmond, WA, USA
#125 Quidleywins , Kyneton Victoria, Australia**
#126 M.Casper (Michael), Perry, IO, USA
#127 Twin_Flyer (Bill), Westhampton Beach, NY, USA
#128 Big Stikflyer (Jay), Machesney, IL, USA
#129 SkinnyBob (Bob), Park Falls, WI, USA
#130 Jetset, (Myles), Picton, ON, Canada**
#131 John Taylor, Macedon, NY, USA
#132 dwreel (Dick), Southern Pines, NC, USA
#133 jimbrock (Jim), Houston. TX, USA
#134 Bandit59, Irmo, SC, USA
#135 Check6, (Fred), N.Scituate, RI, USA
#136 OldScaleGuy, (Steve), Seymour, IN, USA
#137 N1EDM, (Bob), Brockton, MA, USA
#138 Str8aero, (Lee), Sheridan, WY, USA
#139 SAProbuster, (Bob), San Antonio, TX, USA
#140 TomCrump, (Tom), Traverse City, MI, USA
#141 spaceworm, (Richard), Guilford, CT, USA
#142 a8ter, (Larry), Dickinson, TX, USA
#143 NC state, (Tom), Albuquerque, NM, USA
#144 mac2286, (Jimmy), Commiskey, IN, USA
#145 crawler tech, Cocoa, FL, USA
#146 RobMason, (Rob), Henderdsonville, NC, USA
#148 Redtail (Chic), Alexandria, VA, USA
#149 golf4two, (Rick), South, GA, USA
#150 Bcool831, (Barry), Macomb, MI, USA
#151 mariok, (Mario), Valinhos, Brazil**(Director of COBRA (Brazilian equivalent of AMA)
#152 Lucky Do, (Mike), Columbus, IN, USA
#153 dogs4dux, (?), Fronhna, MO
#154 mgnostic, (Matt), Kamay, TX,USA
#155 Yank II, (Jim), Salom, AZ
#156 Jerry-RCU, (Jerry), Siler City, NC, USA
#157 Deanz406, (Dean), Latrobe, PA, USA
#158 smkrcflyer, (Steve), Hamburg, PA, USA
#159 PaulD, (Paul), Coquitlam. B.C., Canada**
#160 Modeltronic, (Pete), Cross Plains, TX, USA
#161 Michael wood, (Michael) Linden, TN, USA
# 162, (Paul), Santee, CA, USA
# 163 RAMMJETT, (Roger), Nobel ON. Canada **
# 164 khodges, ( ? ), Newton, NC, USA
#165 Skyrydr2, (Keith), Tenpteton, MA, USA
Happy Flyin'
Rich
Balsa USA Brothers
#3 ARUP KY USA
#20 pending IN USA
#51 otterrc FL USA
#68 pending CA USA
#87 Chevelle NY USA
#111 mbnt, IL, USA
#120 Jim Scott, ?
Happy Flyin'
Rich
#2125
My Feedback: (17)
Jerry, I changed it, I wish others would ask me to change theirs if needed. I think it bring us closer together.
Stay Safe Brothers
Rich
Balsa USA Brothers
#3 ARUP KY USA
#20 pending IN USA
#30 s3nfo, (Jerry), Queen Creek, AZ, USA
#51 otterrc FL USA
#68 pending CA USA
#87 Chevelle NY USA
#111 mbnt, IL, USA
#120 Jim Scott, ?
Happy Flyin'
Rich
Stay Safe Brothers
Rich
Balsa USA Brothers
#3 ARUP KY USA
#20 pending IN USA
#51 otterrc FL USA
#68 pending CA USA
#87 Chevelle NY USA
#111 mbnt, IL, USA
#120 Jim Scott, ?
Happy Flyin'
Rich
