Reload this Page >
G&L 1/5 DHC chipmunk - diary of a build.
Old 07-17-2014, 09:17 AM
  #326
TonyBuilder
TonyBuilder's Avatar
Belly extension.
To create the detailed belly I need to extend the bottom of the fuselage to the end of the wing.
I found a scrap piece of carbon fiber layup I made for the prototype of my P-47 that worked great.
I cut this to fit flush to the back cut out of the fuselage, and to keep the shape of the fuselage as it moves forward.
I taped a strait edge to the bottom center of the fuselage to keep my extension on the correct plan.
Some blue tape to seal the joint and get it ready to glass.
I am glassing the inside being the piece I installed already has a finish on it and it will just need some easy sand to clean up the joint.
I made a plywood mount so I could move over to the construction plane jig. This will be used throughout the build for construction, detailing and painting. It allows me to work on the plane with or without the cowl.
TB
Name:	wing belley 004.JPG
ID:	2014942   Click image for larger version
Name:	wing belley 006.JPG
ID:	2014943   Click image for larger version
Name:	wing belley 007.JPG
ID:	2014944   Click image for larger version
Name:	wing belley 008.JPG
ID:	2014945   Click image for larger version
Name:	wing belley 019.JPG
ID:	2014946   Click image for larger version
Name:	wing belley 020.JPG
ID:	2014947   Click image for larger version
Name:	wing belley 021.JPG
ID:	2014948   Click image for larger version
Name:	wing belley 022.JPG
Name:	wing belley 023.JPG
ID:	2014950   Click image for larger version
Name:	wing belley 024.JPG
Old 07-17-2014, 11:40 AM
  #327
TonyBuilder
Main spar.
The main forward spar is cut into the wing from the bottom. I first cut a 1/4" trench then with sanding blocks I sand it to the 3/8" diameter.
A template is cut first out of some 3/32" balsa, then the spar is cut from 3/8" 7 ply birch.
after dry fitting the area is masked off with blue tape and the trench is filled with gorilla glue. A small brush spreads the glue to all the walls.
The spar is moistened with water to kick off the gorilla glue. within minuets the glue starts to foam out.
I will let this dry for a few hours before I sand it flush with the bottom of the wing.
On to the rear spar.
TB
Name:	main spar 001.JPG
ID:	2014972   Click image for larger version
Name:	main spar 002.JPG
ID:	2014973   Click image for larger version
Name:	main spar 003.JPG
ID:	2014974   Click image for larger version
Name:	main spar 004.JPG
ID:	2014975   Click image for larger version
Name:	main spar 005.JPG
ID:	2014979   Click image for larger version
Name:	main spar 007.JPG
ID:	2014981   Click image for larger version
Name:	main spar 008.JPG
ID:	2014982   Click image for larger version
Name:	main spar 009.JPG
Name:	main spar 010.JPG
ID:	2014984   Click image for larger version
Name:	main spar 011.JPG
Old 07-17-2014, 01:24 PM
  #328
Leroy Gardner
Well as you usually do, you cover all the bases with detail and the usual good job. Hows your schedual regarding completion, will you fly it this summer, this was suppose to be a quick build so you could. Well there still is 3 months of fair to good weather ahead here, thats if an early Fall dosen't get us. I'm thinking an Indian summer would be great but I don't have much to say about that. Anyway I hope you get to fly it in the not too distant future.
Leroy
Old 07-17-2014, 01:41 PM
  #329
box car
in my 60 years of flying I never have seen any wing dowels sheared off
Old 07-17-2014, 05:07 PM
  #330
TonyBuilder
Leroy, I have maybe 5 weeks into the build and after I get the wing mounted all I have left is the canopy. Yes it is a quick build, but I'm cursed with detail. I am working the next two months on it so should have it done before that.
Our flying season goes from June threw January or February, then the wind kicks in so I'm good.
TB
Old 07-17-2014, 08:05 PM
  #331
Zor
Banned
Default Shearing dowels
That is not surprising. Typical shearing forces for some use in models is as follows.
Basswood ... the weakest ......... 370 psi
Birch ....................................... 600 to 1080
Pine ........................................ 600 to 1000
Maple ..................................... 740 to 1470
Hickory ................................. 1560 to 1980
The lowest 1/4 inch diameter dowel at 600 would typically shear at 29.45 lbs.
It is also possible that the material into which the dowel is inserted may itself fail.
Having said that, it is always wise to use two dowels inserted into hard plywood of sufficient thickness and the hole far enough from the edge ( birch ).
Zor
Old 07-18-2014, 02:53 AM
  #332
TonyBuilder
It is just a personal preference on larger models of 25-40 lb to use steel or aluminum for wing dowels, probably over kill but it gives me piece of mind.
TB
Old 07-18-2014, 02:59 AM
  #333
TonyBuilder
Wing belly.
I started to shape the wing belly.
remember when I started to do the cowl and cutting the engine doors in, that dreadful feeling of "what have I done". Well I had that feeling once I started doing the wing belly. But as I got more into it and the shape started to form that feeling slowly went away, slowly!!
I have the rough shape and it looks ugly but it will clean up once I fit it to the wing.
I wont cut in the rear spar until I am closer. Then I can scribe it and there wont be a lot of sanding to do on it.
This area once I get it close will get glassed then I can finish it off with easy sand.
Been a rough few hours
TB
Name:	wing belley2 001.JPG
ID:	2015130   Click image for larger version
Name:	wing belley2 003.JPG
ID:	2015131   Click image for larger version
Name:	wing belley2 004.JPG
Old 07-18-2014, 03:09 AM
  #334
Melchizedek
Melchizedek's Avatar
Men who have balls of steel take the spoils
Try not to clack them.
Kevin
Old 07-18-2014, 03:33 AM
  #335
TonyBuilder
On the bench for today will be to install the wing dowels, rear spar and wing bolt blocks. I really cant do the final fitting until the wing is secured as it will be in the end.
TB
Old 07-18-2014, 05:25 AM
  #336
FlyerInOKC
FlyerInOKC's Avatar
TB you are giving me ideas again! I have to replicate this wing to fuselage fit with a built up wing. A point in my favor the wing is constructed with a main and rear spar with slotted ribs so I think I see a may of pulling it off looking at your airplane.
Mike
Name:	Ryan SCW N18914 rrq.jpg
ID:	2015137   Click image for larger version
Name:	Ryan SCW N18914 right profile.jpg
Old 07-18-2014, 05:32 AM
  #337
TonyBuilder
OKC, nice plane, if there is a will there is a way
TB
Old 07-18-2014, 05:38 AM
  #338
TonyBuilder
Rear spar.
Rear spar is installed and drying.
The spar is fabricated the same way as the main spar, 3/8" ply
The rear spar will help keep the rear section strong and it will also have the wing bolts attached to it. Not sure if I will go in front or behind the spar.
I need to clear up the rear section and figure out how the connection to the rear fuselage and the rear of the wing will look like.
The wing dowels will be next and will go all the way back to the rear spar, hopefully
TB
Name:	rear spar 001.JPG
ID:	2015138   Click image for larger version
Name:	rear spar 002.JPG
Old 07-18-2014, 06:16 AM
  #339
Melchizedek
Tony
Your endents look great.
The underside if the wing will look awsome.
Well worth the effort. Cudos
Kevin
Old 07-18-2014, 06:38 AM
  #340
FlyerInOKC
FlyerInOKC's Avatar
You are making a vast improvement to this kit. Well done!
Old 07-18-2014, 09:18 AM
  #341
TonyBuilder
Thanks guys.
TB
Old 07-18-2014, 09:46 AM
  #342
TonyBuilder
Wing dowels.
So the rear spar came out good.
I decided to cut the rear section of the wing belly off at the flap hinge line. It will work out much better to make that section part of the fuselage.
I faced it with some 3/32' balsa to hold it together during construction.
The wing bolt block will go right behind the rear spar.
I used a piece of med density balsa and drilled two 3/4 " holes for some hard wood dowels.
Then I glued them in with epoxy.
The T-nuts will go into a piece of 3/8' ply that will be glued to the inside of the wing saddle.
Fitting the rear wing belly section to the fuselage will give me a much better finish, and it will be stronger this way.
I drilled the holes first in the fuselage for the wing dowels then mounted the wing held with tape and marked the holes with a sharpie from inside.
Two 1/4 aluminum dowels will go from front threw the main spar and into the rear spar.
I drilled them threw and got lucky, they both came out of the rear spar in good locations
The wing fits great and I will add a piece of ply to the inside of the fuselage once the wing is all fitted and bolted.
The rear wing bolt block will sit right over the mounting ply.
I glued the dowels in with gorilla glue to fill all the voids in the foam from drilling, but mainly the dowels are in the front and rear spars.
The wing bolt block are glued with 30 min epoxy and once this sets I will pin it to the rear spar with two 1/4" dowels.
Moving right along.
TB
Name:	wing dowls 001.JPG
ID:	2015207   Click image for larger version
Name:	wing dowls 002.JPG
ID:	2015208   Click image for larger version
Name:	wing dowls 003.JPG
ID:	2015209   Click image for larger version
Name:	wing dowls 004.JPG
ID:	2015210   Click image for larger version
Name:	wing dowls 005.JPG
ID:	2015211   Click image for larger version
Name:	wing dowls 006.JPG
ID:	2015212   Click image for larger version
Name:	wing dowls 007.JPG
ID:	2015213   Click image for larger version
Name:	wing dowls 008.JPG
Name:	wing dowls 009.JPG
ID:	2015215   Click image for larger version
Name:	wing dowls 010.JPG
ID:	2015216   Click image for larger version
Name:	wing dowls 011.JPG
ID:	2015217   Click image for larger version
Name:	wing dowls 012.JPG
ID:	2015218   Click image for larger version
Name:	wing dowls 013.JPG
ID:	2015219   Click image for larger version
Name:	wing dowls 014.JPG
ID:	2015220   Click image for larger version
Name:	wing dowls 015.JPG
ID:	2015221   Click image for larger version
Name:	wing dowls 016.JPG
Name:	wing dowls 017.JPG
ID:	2015223   Click image for larger version
Name:	wing dowls 018.JPG
ID:	2015224   Click image for larger version
Name:	wing dowls 019.JPG
ID:	2015225   Click image for larger version
Name:	wing dowls 020.JPG
ID:	2015226   Click image for larger version
Name:	wing dowls 021.JPG
ID:	2015227   Click image for larger version
Name:	wing dowls 022.JPG
ID:	2015228   Click image for larger version
Name:	wing dowls 023.JPG
Old 07-18-2014, 12:23 PM
  #343
FlyerInOKC
FlyerInOKC's Avatar
Looking good, I'm interested to see how the part attached to the fuselage works out.
Old 07-18-2014, 12:39 PM
  #344
TonyBuilder
Should be pretty strait forward, much easier making it part of the fuselage.
Should be done mounting the wing tomorrow.
TB
Old 07-19-2014, 02:09 AM
  #345
TonyBuilder
Now that the wing is done I will install the main gear so I can get her on her feet, plus I want to balance to see where I am at before I do the canopy.
I am getting ready to install the main gear blocks and the struts.
I made a mold and laid up the strut faring's. I want a removable fairing for maintenance and installation so some carbon fiber will do.
Some easy sand to finish it off.
I will not be using the gear mounts I made, the trunion would stick out of the bottom of the wing, and I cant have that. So I will use the supplied mount.
The mount will sit on a ply deck, I will drill threw that and the mount will sit on top of that, should be easy.
The wing bolt blocks are ready to drill. I will be using steel bolts instead of plastic, as I do on all my planes.
TB
Name:	main gear 001.JPG
ID:	2015527   Click image for larger version
Name:	main gear 002.JPG
ID:	2015528   Click image for larger version
Name:	main gear 003.JPG
ID:	2015529   Click image for larger version
Name:	main gear 004.JPG
ID:	2015530   Click image for larger version
Name:	main gear 005.JPG
ID:	2015531   Click image for larger version
Name:	main gear 006.JPG
ID:	2015532   Click image for larger version
Name:	main gear 007.JPG
ID:	2015533   Click image for larger version
Name:	main gear 008.JPG
Name:	main gear 009.JPG
ID:	2015535   Click image for larger version
Name:	main gear 010.JPG
Old 07-19-2014, 02:15 AM
  #346
TonyBuilder
On the bench for today will be the main gear mounts, bolt the wing, and install flaps, ailerons, and the servos. That should finish the wing and then its glass time. But first some morning fly time, need to get some more time on the DLE55
TB
Old 07-19-2014, 05:21 AM
  #347
TonyBuilder
Strut fairings.
The main gear block on the right wing is cut and the gear installed. I will most likely glue in side rails with ply and then bolt the gear mount plate to that so I can remove it and if I do have a mishap hopefully the block will break loos and not tear the wing mounts out.
The strut fairing is trimmed and I will be cut to size once I determine strut length.
Scale length is 6" from axle center to bottom of wing. I need to make sure I have plenty of prop clearance with the 22-23" props. Planed prop will be a 22x10 Xoar.
Top of the fairing gets a piece of 1/8" balsa to form the top, this is glued in with CA and is only a plug. A piece of carbon laminate will finish out the bottom of the strut fairing.
The top gets one too once I cut it to length.
The strut fairing will be secured with a bracket and two screws.
TB
Name:	gear mount 009.JPG
ID:	2015590   Click image for larger version
Name:	gear mount 006.JPG
ID:	2015591   Click image for larger version
Name:	gear mount 007.JPG
ID:	2015592   Click image for larger version
Name:	gear mount 008.JPG
ID:	2015593   Click image for larger version
Name:	gear mount 005.JPG
ID:	2015594   Click image for larger version
Name:	gear mount 004.JPG
ID:	2015595   Click image for larger version
Name:	gear mount 003.JPG
ID:	2015596   Click image for larger version
Name:	gear mount 001.JPG
Name:	gear mount 002.JPG
ID:	2015598   Click image for larger version
Name:	gear mount 010.JPG
Old 07-19-2014, 07:30 AM
  #348
Zor
Banned
What happened ?
Invalid attachments.
Zor
Old 07-19-2014, 07:54 AM
  #349
TonyBuilder
RCU has been really difficult lately, very hard to post or do anything, been getting worse. I gave up this morning after messing with it for way to long, took me but a min to post the same on RCG!
TB
Old 07-19-2014, 09:06 AM
  #350
TonyBuilder
Originally Posted by Zor
What happened ?
Zor
fixed it!
TB
