Reload this Page >
G&L 1/5 DHC chipmunk - diary of a build.
Old 08-25-2014, 05:45 AM
  #551
TonyBuilder
TonyBuilder's Avatar
Yes and if it is to shinny I can dull it down with the clear coat.
So far no lint problem. I am glad I did not prime it again.
Going in to touch up on the second coat. All the areas that got a second coat look good.
TB
Old 08-25-2014, 06:45 AM
  #552
TonyBuilder
Second coat
Wow this Klasskote paint is awesome.
I am sooooo glad I caned the rattle can. It cost me a good $250 with getting all set up and paint but well worth it.
The second coat went much bett as now I have more of a feel and idea as what to do.
I dialed the gun in to where I was more confident in laying a good wet coat.
Edwin this is a good gun for $70 I don't have a reference but it did me good as a total rookie.
I got good coverage and hit all the spots that needed it.
Conditions where very good this morning, under 80 degrees and very light wind, could not have asked for more.
Working with this paint is not as hard as some may say it is with cleanup and all.
Yes it is glossy and shines bright. I kind of like it and we will see. I need to get some clear so I may get the satin to dull it down a bit, we will see.
I am totally stoked
I will let this cure overnight and then do a closer inspection in the morning.
Off to the GYM to burn of some of this adrenalin
TB
Name:	painting 2 001.JPG
ID:	2025688   Click image for larger version
Name:	painting 2 002.JPG
ID:	2025689   Click image for larger version
Name:	painting 2 003.JPG
ID:	2025690   Click image for larger version
Name:	painting 2 004.JPG
ID:	2025691   Click image for larger version
Name:	painting 2 005.JPG
ID:	2025692   Click image for larger version
Name:	painting 2 006.JPG
ID:	2025693   Click image for larger version
Name:	painting 2 007.JPG
ID:	2025694   Click image for larger version
Name:	painting 2 008.JPG
Old 08-25-2014, 06:53 AM
  #553
Mako17
Mako17's Avatar
Awsome
Old 08-25-2014, 11:22 AM
  #554
FlyerInOKC
FlyerInOKC's Avatar
Love it!
Old 08-25-2014, 11:43 AM
  #555
TonyBuilder
Daily progress
Now that the fuselage is painted and curing I am getting to the cowl and canopy frame.
I striped the rattle can paint using a new 80 grit sanding foam block wet. This worked pretty good and did not scratch the surface all up.
I am getting 95% of the enamel off and will not worry about the rest. I will prime this with the white and sand it so I can detail it again.
Looks like the panel lines survived. I will put chart tape in the lines before I prime, then sand and remove it.
The plan is to get all the small parts ready for the next painting shot.
Ailerons, flaps, ruder, elevator, cowl, canopy, and hatches are all on for the next shoot, then I will do the wing last.
Onward.
TB
Old 08-26-2014, 02:06 AM
  #556
TonyBuilder
On the bench for today, prep the remaining parts for panel lines and rivets.
Priming, filling, sanding, priming.
TB
Old 08-26-2014, 02:36 AM
  #557
TonyBuilder
I gave the fuselage a quick look over while I removed the tape mask.
There are only a few very minor blemishes that will add in the weathering and imperfection of the full scale plane.
I could only find one lone run. It is in a place that wont be seen much so I can wets and it out.
I buried some detail as I put the paint on a little thick.
This side was ok.
When I was painting the first coat I saw this blemish, it looked like bubbles on the left side by the cockpit.
Maybe some water or something got on the fuselage while it was out side. I did keep it covered with plastic until I painted but being under a tree who knows.
The blemish was covered with the second coat so it really is hard to see unless you are counting rivets
Overall it came out much better then I was expecting and looks great.
All the tape masking came off nice and clean.
I wont do the black on the top front until I do the black stenciled littering on the fuselage and bottom of the wing.
This KlassKote paint is precious and I don't want to waist any if I can avoid it.
TB
ID:	2026040   Click image for larger version
ID:	2026041   Click image for larger version
ID:	2026042   Click image for larger version
ID:	2026043   Click image for larger version
ID:	2026044   Click image for larger version
ID:	2026045   Click image for larger version
Old 08-26-2014, 06:49 AM
  #558
FlyerInOKC
FlyerInOKC's Avatar
It's good to have a blemish or two, a model can be too perfect and therefore not realistic.
Old 08-26-2014, 07:46 AM
  #559
TonyBuilder
Daily progress.
Some glazing to fill pinholes.
I laid up the air scoops for the cowl doors last night.
One layer of 5.6oz carbon fiber weave.
I then hit them with easy sand.
They came out great.
I epoxied them down and drilled some small holes on the inside so that the epoxy would pine them to the door.
The scoop on the right side has a sizable hole to let air into the cowl.
The one on the left is far back and does nothing. I did drill a small hole to relive the air in the scoop.
I also got the small scoop at the chine of the cowl glued in. I forgot it the first time around.
It is all primed and ready. I put new chart tape in the old lines to freshen them up.
The doors and scoop are all primed and ready for detailing.
I will wet sand later today then start rivets again.
Can't wait to see some KK paint on these doors.
The elevator, canopy frame, cowl, ruder and cowl doors are all on for detailing this afternoon.
TB
ID:	2026084   Click image for larger version
ID:	2026085   Click image for larger version
ID:	2026086   Click image for larger version
ID:	2026087   Click image for larger version
ID:	2026088   Click image for larger version
ID:	2026089   Click image for larger version
ID:	2026090   Click image for larger version
ID:	2026092   Click image for larger version
ID:	2026093   Click image for larger version
ID:	2026094   Click image for larger version
ID:	2026095   Click image for larger version
ID:	2026097   Click image for larger version
ID:	2026098   Click image for larger version
ID:	2026099   Click image for larger version
ID:	2026101   Click image for larger version
ID:	2026102   Click image for larger version
ID:	2026103   Click image for larger version
ID:	2026104   Click image for larger version
ID:	2026105   Click image for larger version
ID:	2026106   Click image for larger version
Old 08-26-2014, 08:05 AM
  #560
FlyerInOKC
FlyerInOKC's Avatar
The scoops look great another great idea I can steal for my SC-M project!
Old 08-26-2014, 08:31 AM
  #561
TonyBuilder
They actually will help in the pressurizing of the cowl, and they do let a lot of air in.
TB
Old 08-26-2014, 09:22 AM
  #562
rt3232
T/B
Looking great !
What did you use for a mold for the scoops ? as you know they are hard to get nice and even, and your are great.
cheers Bob T
Old 08-26-2014, 12:50 PM
  #563
TonyBuilder
Originally Posted by rt3232
T/B
Looking great !
cheers Bob T
Bob, I made a plug from balsa then glassed it, sanded it and put it on a stick, that's why I was calling it the popsicle
I then wrapped it with plastic wrap and molded CF around it.
TB
ID:	2026149   Click image for larger version
Old 08-26-2014, 01:06 PM
  #564
TonyBuilder
Elevator.
So I am working on the elevator.
Got it all primed and I wet sanded and then hit it dry with 400 grit, cleaned it and it is ready for detailing.
On the right elevator there is a long trim tab. I used chart tape to line this out.
Next is an experiment on the stitching.
The elevator, ruder, aileron and flaps are all fabric covered, as is most of the wing short of the LE to the spar and the tips, those are all aluminum covered.
So I was playing around with the throw away strips from Chads vinyl rivets. I did some test with glue drops and liked the results.
So I talked to Chad and he made me up some vinyl stitching strips. The holes are spaced farther apart then the rivets, and they are oblong.
The idea is to mimic the stitching strips on the full scale.
Chad asked if I wanted serrated edges, but they would be so small and would not be seen once the paint went on so no serrated edges.
The strip on the LE is the throw away vinyl strips from the rivets, the gray ones are the stitching strips.
This will get glue drops in each hole.
So this is a test to see what it will look like. I can prime this and then wet sand to soften it a bit or just paint it a little heavy to cover it good.
Being this is fabric it can be uneven and the glue can be uneven as is the full scale.
Here is the look I am going for.
I hit the holes with glue and on the stitching strips I hit it twice to build it up to the desired bump.
I will have to see how this looks once the glue dries.
TB
ID:	2026151   Click image for larger version
ID:	2026152   Click image for larger version
ID:	2026153   Click image for larger version
ID:	2026154   Click image for larger version
ID:	2026155   Click image for larger version
ID:	2026156   Click image for larger version
ID:	2026157   Click image for larger version
ID:	2026159   Click image for larger version
ID:	2026160   Click image for larger version
ID:	2026161   Click image for larger version
ID:	2026162   Click image for larger version
ID:	2026163   Click image for larger version
ID:	2026164   Click image for larger version
ID:	2026165   Click image for larger version
ID:	2026167   Click image for larger version
Old 08-26-2014, 02:59 PM
  #565
TonyBuilder
Ruder
Ruder gets the stitching to see how that looks.
I am liking this more and more. I think once it gets some paint on it, it will look really good.
The glue drops dry clear so it is hard to see what they look like until they get painted.
I have some water base yellow paint I may drop a few drops into the glue dispenser bottle to give it some contrast.
Installation is pretty fast but I can only do one side at a time until the glue dries.
TB
ID:	2026205   Click image for larger version
ID:	2026206   Click image for larger version
ID:	2026207   Click image for larger version
ID:	2026208   Click image for larger version
ID:	2026209   Click image for larger version
ID:	2026210   Click image for larger version
Old 08-26-2014, 06:01 PM
  #566
rt3232
T/B
Thanks for the reply in post 563 about the scoops, kinda figd that is what you did, been there and done that my self.
Keep up the good work
Cheers Bob T
Old 08-27-2014, 01:46 AM
  #567
TonyBuilder
On the bench for today.
Get the elevator, ruder, cowl, canopy, and cowl doors ready to paint.
I realized I cant detail the ailerons and flaps until I do the wing so I will paint them with the wing.
I am planning to paint tomorrow weather permitting.
TB
Old 08-27-2014, 03:03 AM
  #568
TonyBuilder
The mornings progress.
I got the elevator and ruder finished this morning.
I added yellow pigment to the glue and that makes installation so much easier.
I can see what I have done and when it dries I can see that I did not miss one. The clear it is very hard to see.
I like the way the stitching is coming out and once I paint this I can see how it will look on the wing.
Chad is making me some white vinyl strips for the wing, this was just a trial run.
TB
Name:	ruder elevator 001.JPG
ID:	2026337   Click image for larger version
Name:	ruder elevator 002.JPG
ID:	2026338   Click image for larger version
Name:	ruder elevator 003.JPG
ID:	2026339   Click image for larger version
Name:	ruder elevator 004.JPG
ID:	2026340   Click image for larger version
Name:	ruder elevator 005.JPG
ID:	2026342   Click image for larger version
Name:	ruder elevator 006.JPG
ID:	2026343   Click image for larger version
Name:	ruder elevator 007.JPG
ID:	2026344   Click image for larger version
Name:	ruder elevator 008.JPG
Old 08-27-2014, 06:25 AM
  #569
FlyerInOKC
FlyerInOKC's Avatar
Clever idea reusing the rivet strips to experiment with!
Old 08-27-2014, 07:24 AM
  #570
TonyBuilder
Daily progress.
Got the cowl engine doors done.
I am so glade I am redoing the cowl, this will be much better.
I am doing a different rivet pattern then the first time, much better.
Brake time
TB
Name:	daily progress 003.JPG
ID:	2026380   Click image for larger version
Name:	daily progress 005.JPG
ID:	2026381   Click image for larger version
Name:	daily progress 006.JPG
ID:	2026382   Click image for larger version
Name:	daily progress 007.JPG
ID:	2026383   Click image for larger version
Name:	daily progress 008.JPG
ID:	2026384   Click image for larger version
Name:	daily progress 009.JPG
ID:	2026385   Click image for larger version
Name:	daily progress 010.JPG
ID:	2026386   Click image for larger version
Name:	daily progress 011.JPG
Name:	daily progress 012.JPG
ID:	2026388   Click image for larger version
Name:	daily progress 013.JPG
ID:	2026389   Click image for larger version
Name:	daily progress 014.JPG
ID:	2026390   Click image for larger version
Name:	daily progress 015.JPG
Old 08-27-2014, 12:36 PM
  #571
rt3232
T/B
Really like the change in rivet patterns looks a lot more scale almost like what I did as skin and structures mech a loooong time ago while attending college at the old Convair facility in San Diego.
Cheers Bob T
Old 08-27-2014, 01:37 PM
  #572
TonyBuilder
T/B
Cheers Bob T
I am liking it too, I am learning with every part I do. By the time I get back to Angie I will have this finishing thing down.
TB
Old 08-27-2014, 04:29 PM
  #573
TonyBuilder
Daily progress.
The cowl is ready to paint.
I made a cowl detailing and painting jig so I can work on the cowl as a whole.
It rotates 360 degrees.
I am so glad I redid the cowl rivets and will be painting it with the KK epoxy paint.
It came out really nice.
I will go over it in the morning to check if I missed any rivets
I am planning on painting tomorrow, I cant wait to see what it looks like all painted....nice and glossy
TB
ID:	2026523   Click image for larger version
ID:	2026524   Click image for larger version
ID:	2026525   Click image for larger version
ID:	2026526   Click image for larger version
ID:	2026527   Click image for larger version
ID:	2026528   Click image for larger version
ID:	2026529   Click image for larger version
ID:	2026531   Click image for larger version
ID:	2026532   Click image for larger version
ID:	2026533   Click image for larger version
ID:	2026534   Click image for larger version
ID:	2026535   Click image for larger version
ID:	2026536   Click image for larger version
ID:	2026537   Click image for larger version
Old 08-28-2014, 03:10 AM
  #574
TonyBuilder
Morning progress
I got the finishing touches on the cowl.
Priming points.
Canopy is done and ready for tape mask.
On the bench for today, paint the cowl, canopy, elevator and ruder.
TB
ID:	2026606   Click image for larger version
ID:	2026607   Click image for larger version
ID:	2026608   Click image for larger version
ID:	2026609   Click image for larger version
Old 08-28-2014, 04:51 AM
  #575
FlyerInOKC
FlyerInOKC's Avatar
I know what you say about this airplane not being a major scale project but the level of detail is still impressive and beyond my reach!
