Reload this Page >
G&L 1/5 DHC chipmunk - diary of a build.
Old 09-13-2014, 06:00 AM
  #751
TonyBuilder
TonyBuilder's Avatar
Blue is cooking so this will be the last of the painting....Champagne is waiting
TB
Old 09-13-2014, 07:20 AM
  #752
TonyBuilder
Blue is all laid down.
This is it, the last of the painting.
I will let this set up for a few hours then I will remove the stencil.
Any glue will get cleaned on Monday as to let this all set up good. The longer it cures the easier it is to clean.
Not much I can do today bet nurse the wing and fuselage.
I need to clean the fuselage and make it ready for the dry ink transfers.
I will do some tests first as I have two extra flags. I was thinking of putting one on the inside of one of the cowl doors....as a test.
Then I will do some nomenclatures.
Once this is all done then do final install of any reaming gear, then she gets a good turtle waxing before her trip to the field later in the week. Maybe I will start messing with my telemetry sensors today.
If I can get that all setup then I am home free as far as electronics.
TB
ID:	2031568   Click image for larger version
ID:	2031569   Click image for larger version
Old 09-13-2014, 09:54 AM
  #753
TonyBuilder
Poped the cork on the champagne
All painting is officially completed.
The roundels on the wing came out great....finally something worked
No white was showing and just a tinny bit of bleed threw at the stitching.
I could see that this would bleed as I could not get the vinyl to sit down around the stitching.
All in all they are great and once it cures a couple of days I will clean it with acetone.
The color is not traditional as the red is off and the blue is darker, but that's fine.
The fuselage roundels came out great too.
nice and crisp, ready for nomenclatures.
TB
ID:	2031589   Click image for larger version
ID:	2031590   Click image for larger version
ID:	2031591   Click image for larger version
ID:	2031592   Click image for larger version
ID:	2031593   Click image for larger version
ID:	2031594   Click image for larger version
ID:	2031595   Click image for larger version
Old 09-13-2014, 10:10 AM
  #754
acerc
acerc's Avatar
Looks fantastic Toni!
Old 09-13-2014, 10:19 AM
  #755
TonyBuilder
Thanks Robert, now the real fun begins.
TB
Old 09-13-2014, 11:14 AM
  #756
willig10
Awesome looking Tony. I will now need to confiscate your KlassKote for my bird. haha
Glenn
Old 09-13-2014, 11:41 AM
  #757
redbiscuits
redbiscuits's Avatar
Beautiful, can't wait to see it up close.
Old 09-13-2014, 12:49 PM
  #758
Zor
Banned
TB
To celebrate with you . . .
We are all coming over with more . . . . Hee! . . Hee!
Zor
Old 09-13-2014, 02:34 PM
  #759
TonyBuilder
Thanks guys, this is the time that all the hard work pays off, assembly, setup, and then flying.
TB
Old 09-13-2014, 02:42 PM
  #760
TonyBuilder
So I have been working on the wing all day.
got the flaps glued in and servos hooked up.
Ailerons are hooked up and servos are in.
Been pulling wires all afternoon, 5 in the left wing and three in the right wing
My wing tip nav light cases came today....thanks Chad
I got a two pack of green and red, one set for the chippie, and one set for Angie.
I will work on the lights next.
TB
ID:	2031632   Click image for larger version
ID:	2031633   Click image for larger version
ID:	2031634   Click image for larger version
ID:	2031635   Click image for larger version
ID:	2031636   Click image for larger version
ID:	2031637   Click image for larger version
ID:	2031638   Click image for larger version
ID:	2031640   Click image for larger version
ID:	2031641   Click image for larger version
ID:	2031642   Click image for larger version
ID:	2031643   Click image for larger version
ID:	2031644   Click image for larger version
ID:	2031645   Click image for larger version
Old 09-13-2014, 02:58 PM
  #761
stevegauth30
stevegauth30's Avatar
Tony, I have a hard time believing your just learning to paint. Looks as if you've been doing it for years. You should be quite proud of what you've done. Like Leroy said, you overcame some serious obsticals without ever once loosing your cool, (well, at least not that you let us see.) You learned a lot, as we learned a lot with you. thanks for taking the time to share it with us. Cant wait to see it final assembled and see the maiden video. (if there is to be one. hopefully.)
Old 09-14-2014, 01:28 AM
  #762
TonyBuilder
Thanks Steve, this has been a journey. Yes this is my first glassed, detailed and painted kit, and only my 6th kit build. I have learned so much and Angie will be the benefactor to that. I know how much paint it takes to paint, and how to use the gun and airbrush. I know what gaps to leave on control surfaces, hatches and other parts after glass and paint. How to do multi layered stencils, and overlay colors. 4 months in the making and she is almost ready to fly. I hope to get a video. I will have in cockpit video for sure, but it will be nice to have ground video too.
Going flying today so taking a break today. Got to sharpen my thumbs!
TB
Old 09-14-2014, 03:26 AM
  #763
TonyBuilder
You can only look from 10' away, no close ups
TB
Old 09-14-2014, 03:28 AM
  #764
TonyBuilder
Glenn
Thanks Glenn, your going to have to get your own KK paint, I am keeping all of mine, but I will sell you some trainer yellow paint.........
BTW your bird is coming along and you will be painting in no time.
TB
Old 09-14-2014, 05:03 AM
  #765
Chad Veich
My Feedback: (60)
Tony,
Just FYI, on the 3d printed parts usually 2-3 heavy coats of primer with just a tad of sanding between will smooth out the surface and have it ready for paint. Headed out for the last day of Warbirds Over the Rockies now. Your Chippie and/or Thunderbolt would have been very welcome additions to the show!
Old 09-14-2014, 05:50 AM
  #766
Zor
Banned
Default Trying to figure out and understand clearly.
Originally Posted by Chad Veich
Tony,
I assume ( guess ) that 3d printed parts refers to such things as the name ( writings ) of the registration and other decors that on full size airplanes would have a thickness of 2 or more paint layers. That could be 0.002" to perhaps 0.005" . Same thickness would be on a reduced size model.
The word "printed" is, I think, confusing to me.
I am not crticizing . . . just trying to understand what is being referred to and the 2-3 heavy coats of prime would be to increase the thickness of the paint above the background finish upon which the printing is being done.
Sorry if I am "dumb" _ _ _ I was born that way _ _ _
Zor
Old 09-14-2014, 02:36 PM
  #767
willig10
Tony:
What link are you using for Chad? I only get some architectual stuff.
Glenn
Old 09-14-2014, 04:30 PM
  #768
TonyBuilder
Glenn, that is his web site, should be contact info on it, or just PM him.
TB
Old 09-14-2014, 09:49 PM
  #769
Leroy Gardner
Zor
Zor your not dumb, paint is alot of the guy putting it on, it will vary with primer and how much is sanded off as well as the thickness of the paint you are useing. As an example your car likely has a paint job with a 2 to 2 and 1/2 mill thick paint, to get an idea mike the thickness of that plastic paint tarp that has a 2 mill thickness. The vinyl lettering and many of the vinyl rivets are made from vinyl that is .0015 thick, some can be thicker, best to measure it if need be but in the end you can paint a plane with 1/2 of whats on a car and still get good coverage.
As with most things the user and equipment will determine the out come when it comes to a paint job especially over details. Does that help in any way to answer your question.
Leroy
Old 09-15-2014, 01:36 AM
  #770
TonyBuilder
On the bench today, assembly, dry ink transfers, more assembly, detailing, and anything I can get done today. My plan is to complete the fuselage assembly today and then do the wing tomorrow with a prelim balancing.
TB
Old 09-15-2014, 03:44 AM
  #771
TonyBuilder
Tony:
Glenn
http://www.cwvmodels.com/
TB
Old 09-15-2014, 05:41 AM
  #772
FlyerInOKC
FlyerInOKC's Avatar
TB, the RCAF called they want their airplane back! The markings look great! I'm impressed you painted the roundlets instead of using a decal.
Mike
Old 09-15-2014, 07:33 AM
  #773
TonyBuilder
Thanks OKC, I don't like vinyl decals, plus I need to learn for when I finish Angie.
TB
Old 09-15-2014, 07:44 AM
  #774
TonyBuilder
Mornings progress.
So I got all the gear in and setup, pretty much that is.
I haven't setup all the telemetry but it is connected.
I started at the front and I am working my way back
Cowl is done, doors are on, everything tied down.
The cowl doors fit good and this was the first time I have had them all the way on.
The muffler extensions are on and ready to firer.
I moved the fuel fill and de-fill line to the back opening of the cowl.
Opening the door every time would become a pain.
stab center section is in.
Just got the canopy to install then I can start with the dry ink transfers, nomenclatures and the flag.
That will finish up the fuselage
TB
ID:	2032081   Click image for larger version
ID:	2032082   Click image for larger version
ID:	2032083   Click image for larger version
ID:	2032084   Click image for larger version
ID:	2032085   Click image for larger version
ID:	2032086   Click image for larger version
ID:	2032087   Click image for larger version
ID:	2032089   Click image for larger version
ID:	2032090   Click image for larger version
ID:	2032091   Click image for larger version
ID:	2032092   Click image for larger version
ID:	2032093   Click image for larger version
Old 09-15-2014, 11:41 AM
  #775
stevegauth30
Wow! Oh so very impressed I am.
