Flatten Rolled Drawings >
Old 02-22-2016 | 04:01 PM
Default Flatten Rolled Drawings
How can you flatten the tightly rolled drawings so they can be used for building on? I tried to roll them backwards on a cardboard roll but they still curl up tightly in the original direction. The sheet is quite large, about 3' by 4'.
Old 02-22-2016 | 05:56 PM
Tape the corners and middle edges to your building board, smoothing out the plans as you go. Use masking tape.
Old 02-22-2016 | 06:25 PM
If the plans have been rolled and stored for say 10 years, then after rerolling them in the opposite direction you must store them for another 10 years rolled that way for them to be flat. Or you could just pin, tape, and thumbtack them to your building board and get on with the build.
Old 02-22-2016 | 06:53 PM
I'd try ironing them. Start with a low temperature, and work your way up. I'd only try steam as a last resort, but it might just be the ticket to success. Good luck, and let us know if it worked.
Old 02-22-2016 | 08:49 PM
skylark-flier's Avatar
I may have been lucky with mine but I've used a light water spray on the back side and then ran a heat gun (my wife's hair dryer, actually) over them. Worked just fine.
Old 02-22-2016 | 09:04 PM
BrightGarden's Avatar
I'm looking at storing my rolled plans flat between two inward-facing sheets of hardboard panel boards from Home Depot, the stuff with a smooth white finish and acrylic coating.Maybe create "voids" so the pages can breathe, not mildew. Short term, maye very lightly misting then ironing as mentioned.
Old 02-23-2016 | 05:31 PM
My Feedback: (19)
That's what I do. Just iron them and it usually takes a fairly high temp. They flatten right out with little effort. I've done that many times. No water or steam was ever necessary.
Old 02-24-2016 | 03:58 AM
TomCrump's Avatar
Just about every kit I build is over 20 years old. You're right. I just lay the plans out, secure the corners, and build from them.
Old 02-25-2016 | 12:31 PM
Hmm. So every few years, I should take out the drawings, roll them backwards and put them back in the box until the next re-rolling? My oldest kit, partially built, I bought in 1962.
Old 02-25-2016 | 02:24 PM
TomCrump's Avatar
Just lay you plans out and use them. That's what most of us do.
Old 02-25-2016 | 04:31 PM
Hopefully the Kaos will start that trend!
Old 02-28-2016 | 02:00 PM
Backrolling them got them to the point where I could get then scanned and copied as I did not want to hack up the originals. Time to get building.
