Dynaflite PT19 Plans >
Old 04-06-2016 | 10:23 AM
Default Dynaflite PT19 Plans
Just purchased a Dynaflite PT19 Kit, the plans included 1 sheet for both wing panels and stabilizer, and 1 sheet of the side view of the fuselage. There was no top view of the fuselage. I don't know if this was a early version of this kit or if none of the plans show the top view. If anyone has any info or a set that includes the top view, please contact me. Thanks. [email protected]
Old 04-07-2016 | 06:05 AM
Bax
The plans set you have is correct. There is no top view of the fuselage. It's really not needed. There are a few cross-section views you can use to help build the fuselage, but the parts are the main guide. Just draw a centerline on the parts and use that against the centerline you draw on your building board to build it straight.
Old 04-07-2016 | 08:35 AM
Old 04-07-2016 | 09:48 AM
Ditto - pulled out my NIB kit and plans are the same as your description. Checked my Jim Pepino pans (87" wingspan) it has a top view if you really need one. get the same results with a good 3-view.
Old 04-07-2016 | 09:53 AM
ID:	2156268   Click image for larger version
Name:	3 view top.jpg
Old 02-10-2023 | 10:28 AM
My Feedback: (243)
Default Pt-19
Hello,
I am desperate to find the plans for the wing of the Dynaflite PT-19. Any chance I could get yours or a copy of yours? I would gladly pay for it.
Thank you, Patrick
