Battery placement questions.
![](/forum/images/badges/premium_member.png)
I am building a Citabria Pro from Balsa USA. I have the servos, receiver, batteries, engine and fuel tank roughly where I want them to go and checked the balance to get an idea if anything needs to be moved and I found the plane to be very nose heavy. One thing I could do is move the ignition battery back but I am not sure if having the receiver battery and ignition system battery close to one another would be a problem or if having either or both batteries close to the receiver would be a problem. I know it is recommended to keep the ignition system as far away from the servos as possible. I do not know if that includes the batteries.
After building but before covering, I always balance my plane to see if it's nose or tail heavy. I use the battery's own weight to reduce or eliminate the need for additional "dead" weight by moving the battery forward or backward to balance a plane out. Many times I have had to place the battery next to one of the two or three receivers that I have in my planes and it has not caused me any type of interference problems.
Consider yourself lucky that your plane is nose heavy, as much less weight will need to be added to the rear to balance her out compared to a tail heavy situation. Good luck and don't forget to also balance her laterally as well...
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
Moving the receiver pack is a good call. I put together a GeeBeeR2 and by putting the receiver pack underneath the fin, I didn't need to use any extra weight. (used a weed eater motor) Also build nice access panels like servo doors on your plane. Believe me you will never regret easy repair work down the line.
