Reload this Page >
New Balsa USA Smoothie XL Build
Old 11-04-2016, 02:46 PM
RICKSTUBBZ
RICKSTUBBZ's Avatar
Originally Posted by smkrcflyer
Fred,
She is looking good. Are the flaps optional so that you could have a long aileron? I don't need the flaps.
I bet the flaps will be a blast to play with though....
jwrich
My Feedback: (17)
jwrich's Avatar
The Balsa USA guys were at our Okie Dawn Patrol in June and they had the Smoothie on display. I wish I had looked at it a little closer. It is just about the right size for me.
Rich
Old 11-04-2016, 02:52 PM
smkrcflyer
smkrcflyer's Avatar
True, maybe flapaileron.
Old 11-04-2016, 03:18 PM
Check6
My Feedback: (427)
Flaps are optional, so you will end up with basically a large strip aileron. I don't think you can go wrong either way. I'm used to flying with flaps on large , heavy warbirds. Take a look at my Corsairs flaps, they will give you a headache. LOL With full flaps, the Corsair comes in like a trainer. Let us know what you decide.
Fred
Old 11-05-2016, 08:31 AM
Check6
My Feedback: (427)
OK, started on the stab and rudder. First pin down your templates over wax paper. Then I soak the laminating strips in warm water. I submerged the whole stack in the bath tub for around 20 min. They come out like a wet noodle. Lay one strip down and apply glue, continue stacking them until you have six strips. I then wipe off excess glue with a wet paper towel. I start pinning them around the template. When you get to the tight radius, I use the heat gun on it which really allows for a tight radius without breaking any sticks. Continue pinning around until it's complete. I then wash off excess glue with a wet paper towel. The hardest part of this is waiting for the glue to dry. LOL
ID:	2189034   Click image for larger version
ID:	2189035   Click image for larger version
ID:	2189036   Click image for larger version
ID:	2189037   Click image for larger version
Old 11-05-2016, 09:43 AM
  #31
RICKSTUBBZ
RICKSTUBBZ's Avatar
That's an interesting way of doing the laminated tail parts. Until now I had only seen it done by wrapping one strip at a time around the form.
I'd reckon your way is a little quicker and cleaner.
From the looks of it, you had no real problems wrapping them around the radius with all six strips at once?
That's cool that using the heat gun allowed you more ease of wrapping the radius also. That's a new one for me as well.
Old 11-05-2016, 10:15 AM
  #32
Check6
My Feedback: (427)
The key is to get the strips good and soaked. When you take them out of the water they pretty much bend over upon themselves. The heat gun really loosens the fibers up and makes them very pliable.
Old 11-05-2016, 10:23 AM
  #33
Check6
My Feedback: (427)
Just finished making my sheets to cover the fin, stab, rudder and elevators. This is the way I do it, I'm sure there's other methods. This is quick and painless. Make sure you have a straight edge where you mate the sheets. I then put a few pieces of tape to hold the sheets together. Then I run a long strip over the joint. Do this for all the sheets. Now flip the whole sheet over and lay the first sheet over your work bench edge. Now you have a hinge section. Apply glue, use water based carpenters glue for easy cleanup.
Continue doing this for all the sheets. When finished, wash all the excess glue from the joints. You will have a nice seamless sheet when the glue dries. Don't use CA, you won't be able to sand the joints. When I complete all the sheets , I lay them on the workbench with a sheet of waxed paper between them to keep them separated. I then weigh them down because when you wash the glue off, the sheets tend to bow up. Weight them down until they are dry. Pictures in the next post. Hope this helps.
Old 11-05-2016, 10:26 AM
  #34
Check6
My Feedback: (427)
Sheeting pics
ID:	2189045   Click image for larger version
ID:	2189046   Click image for larger version
ID:	2189047   Click image for larger version
ID:	2189048   Click image for larger version
ID:	2189049   Click image for larger version
Old 11-05-2016, 10:29 AM
  #35
Check6
My Feedback: (427)
Guys, Sorry for the multiple posts on the pics. Computer is acting up. When I click on the picture two images show up. I won't be able to do any more construction today until the glue dries.
Thanks Fred
Old 11-05-2016, 01:38 PM
  #36
pappy35
I will be doing this after dinner tonight. Great timing.
Old 11-05-2016, 03:27 PM
  #37
Check6
My Feedback: (427)
Glad, I could help.
Fred
Old 11-05-2016, 07:58 PM
  #38
pappy35
The two rudder laminations went smoothly but the stab has a much sharper radius and proved to be quite troublesome. I got it laid on but when I do the other side tomorrow I'll try using the heat gun.
Old 11-06-2016, 02:22 AM
  #39
Check6
My Feedback: (427)
Mine went around very easily. Maybe the laminating strips in your kit were harder than mine. My strips were made from very soft balsa. The heat gun will help. Use slow even pressure against the strips and they should go fine. Keep us posted.
Fred
Old 11-06-2016, 03:56 AM
  #40
Check6
My Feedback: (427)
removed the laminations from the forms and the sheeting is complete. Trial fit the laminations on the plans. Perfect fit.
ID:	2189112   Click image for larger version
ID:	2189113   Click image for larger version
Old 11-06-2016, 11:02 AM
  #41
pappy35
Did the 2nd stab lamination and all the sheeting this morning. Used a heat gun but I still broke one of the six. They were a combination of very light to medium grade balsa, of the 24 pieces total, I'd say about 18 were super light and the rest were medium density. The parts I made last night fit perfectly. I really like this method of forming curved structural parts.
NOTE: For those building one of these, the instructions had a typo regarding the makeup of the sheeting you edge-glue together. The correct procedure is to edge glue five 3" x 1/16" x 30 sheets to make one piece of sheeting, and three 3" x "1/16" x 36 and one 2" x "1/16" x 36 to make two pieces of sheeting. When you're done you should have one sheet that's 15" x 30" and two sheets that are 11" x 36".
Old 11-06-2016, 03:48 PM
  #42
JCOKEEFE
I've been building a few years and have never heard of the heat gun procedure. I soaked my strips with water and they bent very nicely. I have finished the building portion of the Smoothie XL project and am now starting the sanding, balsa filler process before I start covering.
Old 11-07-2016, 04:03 AM
  #43
VincentJ
VincentJ's Avatar
Check6, your laminations look very good! The strength that you get by laminating a few sticks together is incredible. I made up some soaking fixtures out of different length PCV piping. One end is caped while the other end has a screw off top, it makes the soaking process so much easier. Frees up the bath tub as well. Keep up the good work.
Old 11-07-2016, 04:04 AM
  #44
Check6
My Feedback: (427)
Hi Jerry,
Looks like you have a good head start on me. Good job. I have used heat to bend sheeting for years.
I use an old flat iron to bend balsa sheeting. Wet the sheet and gradually pull up on the sheet while applying heat. Get a lot of steam and a perfectly bent sheet. This is how to sheet the gull wing on a Corsair painlessly. Like you my strips formed easily around the stab cutouts without heat, but heat does help in stubborn places. Use what your comfortable with. Thanks for the input and post some inspirational finished photos to keep us motivated. LOL
Fred
ID:	2189211   Click image for larger version
Old 11-07-2016, 05:06 AM
  #45
Check6
My Feedback: (427)
Vincent , great idea with the PVC soaking tubes. I finished framing up the tail surfaces. Then block sanded everything smooth and flat, then glued on the sheeting that was previously made. I used water based carpenters glue on all the frame work, put the sheeting down and then a 1/4 in. plywood sheet with weight on it to keep it flat until it dries. Pictures posted in the next reply.
Fred
Old 11-07-2016, 05:09 AM
  #46
Check6
My Feedback: (427)
ID:	2189217   Click image for larger version
ID:	2189218   Click image for larger version
ID:	2189219   Click image for larger version
ID:	2189220   Click image for larger version
Old 11-07-2016, 09:23 AM
  #47
Check6
My Feedback: (427)
I rough trimmed the top sheeting and installed filler blocks and hardpoints for control horns. Glued down the sheeting on the other side. Starting on the fuse now.
Fred
Old 11-07-2016, 12:00 PM
  #48
Check6
My Feedback: (427)
Started constructing the fuse. Glued fuse sides together, as well as fuse formers. The front fuse box is taped together to check for fit then glued together. I'm running out of parts in my kit. This is a good thing. LOL
ID:	2189280   Click image for larger version
ID:	2189281   Click image for larger version
Old 11-07-2016, 05:10 PM
  #49
Check6
My Feedback: (427)
Got the fuse sides glued on as well as all the fuse formers.
ID:	2189301   Click image for larger version
Old 11-08-2016, 03:52 AM
  #50
knuckleball
knuckleball's Avatar
Check6,
Your build looks excellent especially the wing servos and trays.
Is this the R/C version of the Bob Palmer C/L Smoothie?
