Reload this Page >
TF Beechcraft Bonanza F33A Build
Old 01-30-2020, 07:35 AM
  #726
FlyerInOKC
FlyerInOKC's Avatar
Ah! So the factory built it for this kind of stress.
Old 01-30-2020, 07:38 AM
  #727
VincentJ
VincentJ's Avatar
https://www.bonanza.org/aircraft-ind.../bonanza-f33c/
Old 01-30-2020, 07:50 AM
  #728
FlyerInOKC
FlyerInOKC's Avatar
Watching the video I am reminded of Bob Hoover's demonstration at air shows with the Rockwell Shrike Commander. You got to love a stunt routine that ends with a loop without engine power and a dead stick landing! There I go showing my age again!
Old 01-30-2020, 09:22 AM
  #729
Hydro Junkie
Hydro Junkie's Avatar
The pilot wasn't really doing anything that would not be possible with a standard Bonanza. While it looked good, especially for a 6 seat aircraft, all he was doing was loops, positive G rolls, hammerheads and rudder turns. This kind of shows why I'm not as impressed as others are with a positive "G" roll:
Skypoint (07-22-2021)
Old 01-30-2020, 09:49 AM
  #730
FlyerInOKC
FlyerInOKC's Avatar
I wonder how many orders resulted in that stunt?
Old 01-30-2020, 01:01 PM
  #731
Hydro Junkie
From what I heard, there was so many orders that it almost bankrupt several competitors
Old 01-30-2020, 01:10 PM
  #732
FlyerInOKC
FlyerInOKC's Avatar
A little 707 trivia! When American Airlines added the 707 to their fleet for the coast to caost flights between NYC and LA they only had 2 mechanics trained on the new plane to start at the two stations. One member of each team had to my onsite to meet the aircraft when it landed. My father in-law was half of the NY team. It took them 6 months to get all their mechanics up to speed. He got a lot of overtime that 6 months.
Old 01-31-2020, 06:29 AM
  #733
Tony Hallo
TOPFLITE TOP FLITE BEECHCRAFT BONANZA CANOPY FRONT WINDSCREEN - acercmodels
Old 01-31-2020, 06:34 AM
  #734
FlyerInOKC
FlyerInOKC's Avatar
Nice find Tony!
Old 01-31-2020, 07:44 AM
  #735
VincentJ
VincentJ's Avatar
Wow, Tony you're the man. It's located in Australia! I bought it though....Thank you!!!
Old 01-31-2020, 07:50 AM
  #736
FlyerInOKC
FlyerInOKC's Avatar
That should make life a little easier but a tad expensive.
Old 01-31-2020, 10:07 AM
  #737
Tony Hallo
Trust me, if he made a mold , plug, vacuum forming equipment, and bought the PEG. He would spend a lot more the $55 and shipping from Australia. The PEG I ordered was $100 minimum order.
Old 01-31-2020, 10:28 AM
  #738
VincentJ
VincentJ's Avatar
Yes you are absolutely right Tony, and not to mention all of my time too!!!
Old 01-31-2020, 12:14 PM
  #739
FlyerInOKC
FlyerInOKC's Avatar
Yeah, its worth saving building time!
Old 01-31-2020, 12:41 PM
  #740
Tony Hallo
I dear friend of mine favorite saying was "God gave you the time for free" that's what think about when I'm building. Enjoy building.
Old 01-31-2020, 04:22 PM
  #741
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
https://www.youtube.com/watch?v=2JlUvX3HUKQ
Yes, the airplane can do just about anything as long as it has airspeed and kept at a positive G load. However it takes a fair amount of pilot skill to pull that off. One thing I found disturbing when that aircraft mechanic liberated a Dash 8 to commit suicide with. Watching the video while he was performing aerobatics showed him maintaining his airspeed and loading like an experienced pilot although the claim was he has no piloting experience.
Old 01-31-2020, 04:41 PM
  #742
VincentJ
VincentJ's Avatar
Time to make the corrugations!!!
I secured the flap to my work table using simple pine scraps to make sure it wouldn't move. The top pine strip will act as a stop for the router ensuring that each corrugation will be the same length.
I'm using my Dremel Rotary tool for the routing process. I made sure that I turned the rpm's as high as the Dremel tool would go to get as smooth a cut as possible.
I'm using a 1/4" straight router bit (#654). The depth of cut was previously set using a scrap 3/32" balsa sheet making sure it didn't go more than half way through.
Note the star on the fifth corrugation on the right. That's there to remind me that corrugation is shorter than the rest.
I made this angle block which the Dremel will follow enabling me to make straight cuts.
I am going to brush finishing resin into each corrugations, then I will be able to sand smooth.
Old 01-31-2020, 05:19 PM
  #743
Hydro Junkie
You must be talking about that idiot that shut down all of the airspace over the Puget Sound basin a year or two ago. I don't think he really wanted to kill himself, more likely that he wanted to get his 15 minutes of fame. That said, a Dash 8 is a lot like the Douglas Dauntless, highly maneuverable when unloaded. The Dauntless was so maneuverable that it filled in as a fighter at the Battle of Coral Sea when many of the Wildcats were escorting the American strike that seriously damaged the Shokaku. What was even more surprising is that many of the kills the Dauntless was credited that day were against the previously unbeatable A6M Zerosen
Old 01-31-2020, 06:08 PM
  #744
speedracerntrixie
My Feedback: (29)
Vincent, the surfaces look great. One suggestion, brush on the resin and wait a few minutes to soak in and then wipe off. This will greatly reduce your sanding and reduce the odds of distorting the shape of the corrugations.
Old 01-31-2020, 09:00 PM
  #745
FlyerInOKC
FlyerInOKC's Avatar
Those corrugations look great!
Old 01-31-2020, 09:37 PM
  #746
EF
That’s a very convincing nicely done scale effect!
Did it significantly reduce the surface’s torsional resistance? How deep is each channel vs. the thickness of the original sheeting?
Old 02-01-2020, 01:48 AM
  #747
VincentJ
VincentJ's Avatar
Thanks for the tip Speed, I'll try that suggestion...
Old 02-01-2020, 05:11 AM
  #748
VincentJ
VincentJ's Avatar
Thank you Erez. The flaps are still rock solid, I tried to twist them and I could feel no difference. I will try twisting them again once the opposite side is routed as well. The balsa sheeting is 3/32" thick (.093) and on top of that there is the glass along with two coats of resin. After routing, the total depth of cut was .020". I didn't have to go too deep to get the effect that I was looking for. I am very pleased with how well it has turned out.
Old 02-01-2020, 05:14 AM
  #749
VincentJ
VincentJ's Avatar
Nothing has been sanded as of yet, I just wanted to see how they would look on the wing...
Old 02-01-2020, 06:08 AM
  #750
Tony Hallo
Is the right side different because of the wing walk? It normally says "no step".
