Covering Question
I have a Guillow P-51D that has tissue/dope covering instructions. Is it possible to cover with Ultracote? If so, do I need to sheet portions of the wings?
I really belive that standard Ultrcote covering is too heavy a material for a Gillows P-51 you need a light weight covering.
try Coverlite from Tower
http://www2.towerhobbies.com/cgi-bin...te&FVPROFIL=++
or Solar Film Lite
http://www.balsapr.com/catalog/covering/default.asp
John
or Solar Film Lite
John
Thank you both. I should've stated that this, my second powered model, will be powered by an .020, very likely, for free-flight. The ultracote is a dense material and I'll look at the other two recommendations.
Thanks again.
Thanks again.
