The Worst Headaches!
ON, CANADA
I would like to see if I can put your design to good use.
I have the perfect design (on paper), but trying to implement it on a plane is impossible with the current availability of parts.
ABS parts, wood "selection" ("wood selection" is an oxymoron - I have better luck in the lottery than in getting the correct wood in a kit
) and die crunching of super soft balsa [:@]
Cheers!
Jim
) and die crunching of super soft balsa [:@]Cheers!
Jim
