Reload this Page >
Top Flite 1/7 P-51 Build
Old 05-29-2018, 07:41 AM
  #3576
BigTeeEldorado
BigTeeEldorado's Avatar
Originally Posted by hipik634
Its just hard to do that while your engine is off .. With flaps fully extended its logical, but cannot do it without engine ..
I'm sorry I probably missed that part in your post and you are absolutely right, engine is required for that technique. Your only other option is to dive for the runway to keep the speed up and then still do as I suggest and let the wheels touch and get off the elevator. The important factor is the speed so that you can keep some aileron authority until you get the main wheels on the runway, but that extra speed will cause the plane to flair back into the air unless you can get off the elevator stick.
Old 05-29-2018, 08:47 AM
  #3577
acdii
Don't use flaps in a dead stick, they just slow it down too fast. Of my two warbirds, the P-51 and the P-47, have yet to land with flaps on them. I just grease them in, of course gopher holes tend to stop it extremely fast once down.
Old 07-31-2018, 02:02 PM
  #3578
rcuser004
Guest
My Feedback: (287)
Anyone have the plans for this 60 size kit that will sell them?
Mike
Old 10-13-2018, 11:21 AM
  #3579
Dyyrkd1
Does anybody still have the Plans from their Top Flite P-51D 1/7 scale build? I have the kit but for some reason the plans are missing. I would buy them if they are available. Thanks
-Rick
Old 10-14-2018, 10:05 PM
  #3580
hipik634
hipik634's Avatar
-Rick
I do have them, but I intend to keep them; perhaps a digital copy, they are not exactly in good shape ? Did you try to write to Top Flite if they are available ?
Old 10-15-2018, 05:39 AM
  #3581
FlyerInOKC
FlyerInOKC's Avatar
I would call Horizon they may haver a copy since they bought out Top Flite. I have a complete kit in storage so if you don't find them I could get you a copy made and mail it. Might be cheaper to call Horizon though.
Old 10-16-2018, 05:53 PM
  #3582
Dyyrkd1
Thanks! Horizon does not have the plans. Already went there on direction from my local hobby shop. Let me know what you need for them. Can't wait to start the build.
-Rick
Old 10-17-2018, 05:28 AM
  #3583
FlyerInOKC
FlyerInOKC's Avatar
I could probably have them scanned to a pdf file and email it so you could get them printed locally. Would you want to go that route?
Old 10-17-2018, 10:45 AM
  #3584
Appowner
Banned
Have to disagree with you. Engine is preferred but not required. As the wing loading goes up, as it does with fighter types, it becomes all about energy management. Flaps will bleed off your energy. A little throttle compensates for that. If you don't have your engine, then gravity is your friend. Hence your approach will have to be higher and final will be steeper. Flair at the bottom and grease it on.
Thing is, it takes practice. So if you never do it, you won't know how when you need it.
Old 10-21-2018, 11:26 PM
  #3585
hipik634
hipik634's Avatar
Well gravity isn't always your friend ... Hitec Hs-485hb onboard is your worst enemy ... if put on elevator. Lost the plane on low pass as the elevator got stuck. Servo just died. The fuse is almost intact, so I guess I will make a new wing ...
Old 10-22-2018, 04:38 AM
  #3586
FlyerInOKC
FlyerInOKC's Avatar
OUCH! Sorry to hear of your loss. Now that you have room in your hanger what are you going to build to replace it?
Old 10-25-2018, 04:38 AM
  #3587
FlyerInOKC
FlyerInOKC's Avatar
OK guys I was able to get my TF 1/7th scale P-51D plans scanned to pdf and emailed to Rick (Dyyrkd1). Now he has the joy of trying to find someone with a printer in his area that can spit out a 41" wide plan. I was only able to find one place around here that had a scanner that could handle that width. I forgot how big the plans actually are! I think Rick needs to post his build in this thread.
Old 10-25-2018, 04:42 AM
  #3588
acdii
I made copies of the plans for mine and it came out to over $80 due to the size of them. Problem is, I now have three sets of those plans, and no clue where the hell I put them! LOL
Old 10-25-2018, 04:51 AM
  #3589
FlyerInOKC
FlyerInOKC's Avatar
OUCH! That is pricey! Now I don't feel s bad about paying $20. to have them scanned. I don't want to know what he would have charged to print them! I had a plan under a 36" width I was able to get scanned and printed at either Staples or Home Depot and that was less than $10. I guess with a 36" width you have plenty of competition but over 36" they don't and can stick it to you. Hmmm, I just Googled what the printer cost difference between a 36" width and a 42" width and all I can say is WOW!
Old 10-25-2018, 05:16 AM
  #3590
hipik634
hipik634's Avatar
It's great that somebody now has the plan in an electronic version for future reference 👍
meantime I started to make the model for laser cutting off the wing to be able to restore mine to flying condition ...
Old 10-25-2018, 05:26 AM
  #3591
FlyerInOKC
FlyerInOKC's Avatar
Are you going to modify the repaired plane or keep it the same?
Old 10-25-2018, 05:27 AM
  #3592
acdii
Yeah, had to go to a print shop to get them scanned and printed due to the height. What's worse, it wasn't an electronic scan bed either, so no PDF of it, it was a scan/printer like the old school copiers. I have some Corsair plans I need to get printed, and that place closed, so now have to find some other place to get them done.
Old 10-25-2018, 05:44 AM
  #3593
hipik634
hipik634's Avatar
I quite liked the visibility contrast of yellow and silver, so it would be the same, I will just modify the gear holding part due to the experience gained on first evo.
Take a courtesy to view last two flights .... meassured airspeed was somewhere between 190-240 kmh (140-150 mph) on low passes
3d build going quite fast ...
Old 10-25-2018, 06:07 AM
  #3594
FlyerInOKC
FlyerInOKC's Avatar
Nice!
Old 10-25-2018, 06:11 AM
  #3595
FlyerInOKC
FlyerInOKC's Avatar
How I found this guy was I went to this shop that supplies Architects and Engineers. They carries the templates, pencils, paper, etc along with printing blueprints. So I checked with them told them what I needed and the size and they told me about this guy because they use him too. I would check with a shop in your area or an Architectural and Engineering firm. Sometimnes it just comes down to knowing who to ask.
Old 10-31-2018, 02:14 PM
  #3596
hipik634
hipik634's Avatar
so the new wing is ready to be lasered .... reinforced the gear section for electric retracts.
Old 10-31-2018, 02:50 PM
  #3597
FlyerInOKC
FlyerInOKC's Avatar
Nice! I just hope the blocks around the landing gear aren't too heavy.
Old 10-31-2018, 05:20 PM
  #3598
Riddle4U
Yes, I just was just going to suggest this; $80 is a criminal ripoff...
I went to an architectural supply and service shop a few years back to enlarge old Royal .60 size Corsair plans to 1/6th scale. $15; for four sheets of 48” x 72”...
Old 10-31-2018, 10:02 PM
  #3599
hipik634
hipik634's Avatar
I've already flown it with much bigger ones, this is lighter than that ..
Old 11-10-2018, 04:34 PM
  #3600
Pittscrazy
Here is my top flite p-51 . It found me at a swap meet with a $50 price tag . It had no rudder , no cowling , no belly scoop , no motor and no electronics . It does have robart retracts with struts and robart wheels
but no air tank . I scratch built the rudder , made a new fiberglass cowling and spinner and I am working on the belly scoop now . I have a ys 140 L that I plan to use . Oh and I changed the paint scheme to match miss Helen a bit better
