Question about Great Planes Super Aeromaster
I am helping a friend with his super aeromaster. In transport between our houses we have misplaced the fuselage planes. Does anybody know the cg for the short angled top wing and straight short wing configuration? Also what is the distance between the thrust washer and the fire wall? Thanks in advance for your assistance!
TX
RE: Question about Great Planes Super Aeromaster
ORIGINAL: N8theSk8
Here's a link to the full manual at the Great Planes web site:
http://www.greatplanes.com/manuals/g...ter-manual.pdf
Cheers!!!
BobbyG
TX
ORIGINAL: N8theSk8
Thanks! that help a little. but it does not contain the CG for configuration one.
How odd. They only make mention that it appears on the plans.
Since Configurations 1 & 2 are so similar with the only difference being that the lower wing is shorter on #2, it's probably OK to try the CG at the same location as for Configuration 2.
Thrust washer location is referenced to front of cowl - 1/8".
BobbyG
OH
thrust washer is 5 1/8 from firewall with no 2 stroke box,,,,,,,,#1 cg is half the range forward of #2 hope this helps let me know were you want to measure from if you need starting point,,,,I am no expert by any means an am searching for all details I can for this plane thought I would try an give back,,,there are a few recent threads of guys with this plane an I know by there comments they must be very busy,,,so give us guys with drool some comments,,,,Dan
